Raymond easi r35tt no power
Working on a Raymond that had a code 23. Change t1 t2 q1 and power card. The code went toa 26. This morning the lift will not even power on. Shop tech said he pushed the main contractor down with the 26 code on the dash and it just quit powering up. Any clues?
  • Posted 9 Jul 2013 00:36
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
hi there I have been reading your fault which codes relate to motor field are you sure you haven't got a faulty drive motor or cables ?
  • Posted 10 Jul 2013 21:16
  • By electrotech
  • joined 15 Apr'13 - 63 messages
  • Victoria, Australia
Reach for the sky
First, check the power and control fuses. Control fuses are located on the system card if I remember correctly and the power fuses are at the contactors. Before powering back up, check shorts to frame. Under the heatsink that the Q1 and Rec1 (which could also be shorted) are mounted to there is an insulator pad. This will sometimes develop a hole, shorting the above components to the frame of the truck.
  • Posted 9 Jul 2013 23:10
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Battery at 36.7 volts at last check which was Wednesday. Have not checked fuses in contactor panel yet. Truck was powering up and the fingers had to touch it.
  • Posted 9 Jul 2013 08:16
  • By proshadetree
i hate to say this but, is your battery ok?
swoops right probaly blown fuse.
for the code 26 the tm1 and tm2 that were put in, are the leads on the right spots? use the two outside pins on the tm and cut the inside ones off. 26 is open in field circuit 23 is armature.
  • Posted 9 Jul 2013 05:22
  • By stam
Well first I would check are the control fuses to see if it blew any of them.
If you haven't tried this, try unplugging the battery and plug it back in.
If memory serves me I believe there is a fuse panel tucked in the contactor panel. It should have 2 or 3 fuses on it. One of those fuses is the power control fuse.
  • Posted 9 Jul 2013 02:29
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
UN Forklift FBRS15KQZ2
Gillian Reed Gillian Reed
Board director, UKMHA
Director, ICHCA Australia
Senior manager of powered access business development & technical services North America, Noblelift
VP business development for Europe, Noblelift Intelligent Equipment Co
edition #1241 - 31 July 2025
CeMAT Australia was held in Sydney last week with a larger than usual contingent of Chinese OEMs. Forkliftaction speaks with a number of them to find out why they are targeting the Australian market, and what they feel needs to be done to be successful here. It’s an interesting insight into a shift in the market which is seeing some of China's largest companies making a move... Continue reading
August 31 - September 2, 2025 - Sultanate of Oman, Oman
September 9-11, 2025 - Birmingham, United Kingdom
