Linde H25D-03 Engine Speed Control \ Travel Control Unit Issues
One of our newer service techs who has limited experience on linde units. Replaced a few seals On the travel control unit (Double Pedal) in a Linde H25D-03 351 Series With a Perkins. We had no previous issues besides leaking fluid. Unit Idled Correctly and Engine Speed control was accurate.
The issue we are having is the unit starts up and the idle slowly increases to ~75% over a 20 second time frame. & will not go below 75% throttle point. if you go fwd or rev you will get 100% or if you activates the hydraulic the engine will reach 100% but it will not drop below the 75% point.
Is there an adjustment on the travel control unit to the hydraulic engine speed control unit?
Its almost like the travel control unit is slowing pumping fluid in to the hydraulic engine speed control circuit to a certain pressure and stopping. you can push slowly the hydraulic engine control rod lever back by hand at a idle but the process then repeats
I tried to reference documentation on the 350 and 352 series truck to no avail, We have no documentation of the 351 series
Any Help would be great.
Howitt937 at g mail dot com
  • Posted 3 Jul 2013 12:36
  • By Howitt
  • joined 13 Feb'09 - 80 messages
Check mail
  • Posted 3 Jul 2013 18:23
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
edition #1241 - 31 July 2025
CeMAT Australia was held in Sydney last week with a larger than usual contingent of Chinese OEMs. Forkliftaction speaks with a number of them to find out why they are targeting the Australian market, and what they feel needs to be done to be successful here. It’s an interesting insight into a shift in the market which is seeing some of China's largest companies making a move... Continue reading
Neutron stars, the remnants of supernova explosions, have such extreme density that a tablespoonful of their material would weigh over 1 billion tons on Earth.
Hawker Powersource, Inc.
Dallas/Ft Worth, United States
Olathe, KS, United States
