Nissan CWGP02L25S 9E0143 - Traction Code 011
Hello,
Key on Traction code 011 Fwd/Rev unit will attempt to move (Creep) then shut down. Ran Diagnostic - T Fuse - Replace fuse - Still not working. Any Ideas or thoughts
prenticelift at gmail dot com
  • Posted 8 Jun 2013 02:05
  • By Prentice
Showing items 1 - 20 of 27 results.
Missing B(plus) on one of the small fusses in the back with key switch on==> Acid damaged wires in harness under the battery (different color wire spliced together)
  • Posted 4 Aug 2023 02:32
  • By mike_v
  • joined 1 Jul'10 - 190 messages
  • Illinois, United States
mike_retired
Hi guys
I'm getting trouble code 11, 515, 530
When the do the self diagnostic test on the dash it's coming up "t-fuse 527" and "open/voltage under 531"
Any advise much appreciated
  • Posted 4 Aug 2023 02:16
  • By Peter_Hughes
  • joined 26 May'22 - 5 messages
  • Ireland
PD Lift Trucks
Hey y'all,
I'm new on here, I saw you said you Got it.
I'm having trouble with the same kind of forklift.
Nissan 36v electric CWP02L20S.
CODE 011 and 015 we've checked everything and run a self test, and it'll clear the codes, but when I put it in gear forward or reverse, I get the wrench pic and traction 011 code.
PLEASE HELP.
THANKS IN ADVANCE.
  • Posted 21 Mar 2023 02:24
  • By Albert_Estrada
  • joined 21 Mar'23 - 3 messages
Albert Estrada
Dear Sir,
We have Nissan GQ02 series battery operated forklift. We are facing traction trouble 011 issue and error codes are 515, 530. Checked traction motor, transistors, diodes as per manual and found OK but problem not yet resolved, when we depress accelerator pedal FvR contactor released. Please help us to resolve the issue
  • Posted 8 Jul 2021 02:24
  • By Ananthraj_S
  • joined 1 Jun'21 - 8 messages
  • India
This is a transistor control track
  • Posted 5 Jul 2021 11:39
  • By mike_v
mike_retired
  • Posted 5 Jul 2021 11:12
  • Modified 5 Jul 2021 11:13 by poster
  • By mike_v
mike_retired
We are also facing same issue. Did u find the solution for thaat trouble
  • Posted 4 Jul 2021 11:46
  • By Ananthraj_S
  • India
Same problem we are facing in our forklift. Did u find out the solutin
  • Posted 1 Jun 2021 00:37
  • By Ananthraj_S
  • India
If my memory serves me right I remember during acceleration there is a second set of clicks when increasing speed like an overdrive. Not on this fork truck but another that is working properly.
  • Posted 9 Apr 2019 04:29
  • By gene_g
  • joined 9 Apr'19 - 5 messages
  • Wisconsin, United States
Power at fuses
  • Posted 9 Apr 2019 04:14
  • By gene_g
Also forward and reverse contacts will kick out and then reset once you let off the accelerator pedal
  • Posted 9 Apr 2019 04:05
  • By gene_g
B+ is battery power?
  • Posted 9 Apr 2019 03:57
  • By gene_g
Missing B+ on one of the fusses in the back with key switch on. Acid damaged wire in harness under the battery (different color wire spliced together)
Check for B+ voltage all the small fuses
  • Posted 9 Apr 2019 02:54
  • By mike_v
mike_retired
Running into the same problems. Followed trouble shooting tree and checked all fuses. Checked current sensor and swapped controller and associated equipment also. No success. Swapped print board also. No success. Stoned motor and checked brushes and blew out motor. Any thoughts??? Also battery is on floor beside forktruck.
  • Posted 9 Apr 2019 01:31
  • Modified 9 Apr 2019 01:40 by poster
  • By gene_g
  • Posted 26 Jun 2013 00:12
  • By mike_v
mike_retired
GOT IT!!!!
Control Card -re and re card all is good. A big shout out to this form and the techs that helped. You know who you are.
Thanks you very much
  • Posted 25 Jun 2013 02:15
  • By Prentice
bye the way if you are blowing fuses you must have a short somewhere
  • Posted 18 Jun 2013 20:59
  • By electrotech
  • joined 15 Apr'13 - 66 messages
  • Victoria, Australia
Reach for the sky
did you say that you used three traction fuses?? and that the contacts drop out when you press acc silly question your sure the main cables are in the correct position ?? I don't think that the control card would be at fault more likely the main thyristor or the smaller ones req 1&2 need to be checked
  • Posted 18 Jun 2013 20:55
  • By electrotech
Reach for the sky
I have done all above tests. Thank You
Found a Trouble Diagnoses for Controller manual. Symptom F-R contacts release when accelerator pedal is depresses. Checked Motor - OK - Which seems like it's in the Control Card.
1- Is it possible for NEW - T Fuse to have continuity and fail under load - Used three so far -
2- Anyone know where I can locate a #29380-1K210 Card
In Ontario Canada?
  • Posted 18 Jun 2013 07:11
  • By Prentice
"3.make sure that the drive motor and cables are ok because the reason for the t fuse is a broken or loose terminal/cable if you had had a blown fuse it would come up with the same fault so if you had a broken motor cable that is the same as a blown fuse if you follow what I mean"
which also would follow if you had sticking or bad brushes in the drive motor...
  • Posted 15 Jun 2013 21:49
Taylor TT300
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Combilift Ltd
Muncie, IN, United States
