Code 43
Have a code 43. Serial # is EASI-00-AJ27055. Goes thru start up. Codes out once deadman is pressed.
  • Posted 7 Jun 2013 21:59
  • Modified 7 Jun 2013 23:58 by poster
  • By d_rad
  • joined 7 Jun'13 - 9 messages
  • Minnesota, United States
sounds like you have a bad pot in the handle giving you the un-requested lift. test A04 could help diagnose that.
your right, bad batteries are the main cause of contactor issues like you are having. code 42 is welded lift contact.
  • Posted 12 Jun 2013 20:52
  • By stam
Thanks Stam. Lost the code 43. Now have code 42. Acting real funny. If you go to drive the hydraulics kick in, and then codes out. After some hard looking I did find the TM card had a bad circuit board line. I am assuming this would be the only problem but I will find out once I get the new card and test further. I will try to keep you up to date.
By the way the battery is in pretty poor shape. I suspect that is what caused the problem. Customer continued to operate truck when it was dead.
  • Posted 11 Jun 2013 22:25
  • Modified 11 Jun 2013 22:43 by poster
  • By d_rad
code 43 is lift contactor detected open when supposed to be closed. verify it is pulling in and the fuse is good.
  • Posted 11 Jun 2013 19:55
  • By stam
Jeannette Walker Jeannette Walker
Vice president, customer, TVH Americas
Chief executive officer, Seegrid
Chief commercial officer, Meijer Group
Chief executive officer, Hire Industry Association New Zealand (HIANZ)
edition #1249 - 25 September 2025
The US Monthly Confidence Index, measuring the mood of the equipment finance industry, has remained stable for the fourth consecutive month, despite one survey respondent saying “competing economic forces and political strategy collide to create an unusual operating environment”. Read the full story in this week’s news ... Continue reading
November 04-05, 2025 - Houston, TX, United States
December 03, 2025 - New Delhi, India
September 16-18, 2026 - Guangzhou, China
ASSET FINANCE
Nov 2025
