Linde H30T. Possible timing issue
Have a unit that customer replaced water pump. They turned engine over without tightening tensioner, now out of timing. Can't locate pointer for crank shaft. Is it on timing cover? Any help would be appreciated!!!!! Also no markings on cam pulley.
  • Posted 23 May 2013 07:07
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Thanks swoop, I think that's what happened. Did a compression check and #1 has 0, 2 and 3 starts at 30 and after a few rotations winds up at 90, # 4 is strong starting at 90, and ending up at about 130.
  • Posted 25 May 2013 14:22
  • By 1sharpdog
David Sharp
the valve clearances are very tight in these VW engines, if the engine was turned over out of timing there is a 99% chance the valves were damaged. There is even a warning message in the service manual to NOT turn the cam.
Before the belt was removed the crank should have been marked on the intermediate flange associated with the crank pully. Then make sure the cam pulley is on mark while crank is on TDC. The cam pulley should have a mark on it and should be almost between 11 and 12oclock position. The manual says to have the #1 cylinder cam journal lobes in the TDC position, there should be a mark there to identify that on the pulley.
But if the engine was turned over with the timing off you probably have bent valves now.
  • Posted 25 May 2013 00:17
  • Modified 25 May 2013 00:19 by poster
Michael V,
What in the world are you talking about???
  • Posted 24 May 2013 11:49
  • By 1sharpdog
David Sharp
Thank you so much. Quick question. Since this VW engine has been turned over out of timing. What is the chance that valves have hit the piston. Also, I have done compression checks on all cylinders, hopefully in timing position. And the best I get is 90 PSI. This isn't good, huh?
  • Posted 24 May 2013 11:48
  • By 1sharpdog
David Sharp
michel v;
If 1sharpdog receives a service book from other then an authorized Linde NA dealer he has left the door open for a law suite. There is in this session of are Federal Court system a simular case now being decided.
  • Posted 24 May 2013 07:42
  • By MEngr
  • Missouri, United States
Hi , check the camshaft and crankshaft pulleys, they must have a timing point on it. If not you must set cilinder 1 on TDB ( piston on top in cilinder ) Then set the valves of cilinder 1 closen ( not on tumble )
  • Posted 24 May 2013 04:02
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
hi sharpdog,
if you look at bellhousing end of engine you will see a cut out with a roll pin pressed in. When you get engine to tdc there is a 'cut' (looks like angle grinder mark) on flywheel.
double check camshaft and you should see timing mark between 11 & 12 o'clock.
cant remember if there is a mark in crankshaft (maybe a pop mark in cam belt pulley) after you take alternator pulley off.
remember only turn tensioner anticlockwise.
  • Posted 24 May 2013 03:49
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
This is a H30T Serial No. H2X393S03395
  • Posted 24 May 2013 00:06
  • By 1sharpdog
David Sharp
  • By 1sharpdog
David Sharp
What is the series of the truck and production year?
Under H30T you may have 351, 351-02, 351-03/04 and 393. The engines types can be: VW, Perkins, Renault.
Which one you have?
  • Posted 23 May 2013 18:42
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
UN Forklift FD40T
Terberg YT223
Muncie, IN, United States
