Hyster B60Z A230 Code 11
Has no lift or direction.Says code 11 on the hour meter. Hooked up Curtis hand set and said motor sensor? Checked everything suspect the Curtis control box
  • Posted 21 May 2013 11:43
  • By erik_j
  • joined 11 Dec'12 - 19 messages
Condition
Handset is plugged into the traction motor controller. Key switch is in the ON position. Diagnostic menu is selected.
Truck Response
No Traction
Possible Causes and Test Procedures
1. Incorrect traction motor wiring.
Check wiring to traction motor.
Loose, worn, or frayed wires?
Motor wiring correctly installed?
2. Check for motor shorted to frame.
Disconnect leads from motor.
Resistance between frame and motor terminal should be 1 mega ohm or more.
3. Check for controller shorted to B−.
Disconnect motor leads from controller.
Resistance between motor terminals on controller and B− should be 1 mega ohm or more.
  • Posted 22 May 2013 03:52
  • By JimB
  • joined 12 Apr'13 - 30 messages
August 1-3, 2025 - Coimbatore, India
September 18, 2025 - Blair Athol, South Australia, Australia
November 04-05, 2025 - Houston, TX, United States
edition #1240 - 24 July 2025
CeMAT Australia 2025 has been underway in Sydney this week, wrapping up today, with the main topics coming out of the event proving to be the very predictable automation and sustainability... Continue reading
On the 88th day of the year, 29 March in a non-leap year and March 28th in a leap year, World Piano Day (also known as Piano Day) is celebrated. This date was chosen because a standard piano features 88 keys.
ROYPOW
