linde serial393 error code 221 and lifting pomp dont work wen ist hot
hi
i have one linde h35t serial 393 and prolem is error code 221 and wen ist hot dont work hydraulic pomp wen is cold function
help mywith this iformation
thanks
  • Posted 4 May 2013 18:22
  • By adi_m
  • joined 5 May'12 - 75 messages
  • romania, Romania
adi
e mail adress metadonul @ hotmail dot com
you neet phatfinder to fix dis problem
  • Posted 5 May 2013 03:03
  • By michel_v
  • noord holland, Netherlands
Fault 221 Lifting
The controller detects joystick and reference signals of the tilt angle sensor are incompatible. The effect on the truck is a reduced lifting speed.
possible causes are bad connections between tilt angle sensor and controller or tilt angle sensor defective.
Fault 221 traction
Controller detects production test is not OK the effect on the truck is a traction reduced speed.
Possible causes are voltage surges or voltage dips in power supply or controller defective.
regards
  • Posted 5 May 2013 00:12
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
MAXAM Tire, Inc.
