bt transistor controler/curtis with problem c 28
how to repair BT curtis with a problem C28
  • Posted 1 May 2013 10:08
  • By vecky_t
  • joined 23 Apr'13 - 18 messages
  • jakarta, Indonesia
Hi,
I have the same problem with BT SWE 160D PTC resistor heats up and displays an error C28. What causes this condition? Thank you for your help.
  • Posted 6 Mar 2014 17:58
  • By blazej_f
  • joined 6 Mar'14 - 5 messages
  • Pomorskie, Poland
Yes, of course.
Any extra consumption before the main contactor K10 connection causes the heating in the PTC resistor losing curtis controler its feeding.
This is easy to check, in these cases the PTC resistor is too hot (Caution, you can burn your fingers)
Regards
  • Posted 4 May 2013 23:51
  • Modified 4 May 2013 23:54 by poster
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
I have seem stuck lift pump contactor cause this too.
  • Posted 4 May 2013 07:42
  • By rogeriwt
thanks for your advice,friend
  • Posted 2 May 2013 00:19
  • By vecky_t
I guess you're talking about 1243 sepex controller, and this fault usualy occurs when emergency push button is activated.
Could be due to a defective battery / juctions between cells or loosen contacs in battery connector. Also should check PTC resistor fitted in main contactor tips.
Regards
  • Posted 1 May 2013 22:40
  • By nacsand_n
  • Madrid, Spain
Highland, IL, United States
Orlando area, United States
Tacoma, WA, United States
Dallas, TX or Lexington, KY, United States
