Boss/Steinboc WM13 Serial # 273123
HI there
Can anyone share a wiring diagram for this truck as i have been asked to look at a truck which is going slow in drive and also hydraulics are slow. The bosch LT 200 Controller has been tested and shown to be working ok. The motor thermal circuits also checked. Customer suspects something in the additional circuits, however without a wiring diagram we are going to be working blind. Any info will be of great help.
Regards
  • Posted 27 Apr 2013 04:39
  • By elektrodrive
enquiries@elektrodrive.co.uk
will have a look in depot for anything that might help , but check mast switch and lower ones about 1 meter high, can be magnet reed switches or lever arm switches, used to find if reed switches they were moved out of range or broken , thinks mast is still up, i think there are switches on the rotate to house it as well , have seen one with a sensor on top of the cab that picks up on racking and allows full speed
  • Posted 30 Apr 2013 06:13
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
Hi there
Ive not been out to it yet, as most of my work is for the trade, i try talk the engineers through it before hand. if they cannot get it resolved then I have to make the trip out, this looks like one of those cases. I will mention this to them first, but failing that, it would be nice to have a wiring diagram if i need to go out to it.
Thanks for the advice, will check.
Regards
  • Posted 28 Apr 2013 05:12
  • By elektrodrive
is it possible you have a bad sensor on the mast sections? i mean the truck have sensors on the mast. I have repair it by my customer they have the same problem. Everythink works slow. It is a highest level detection and for safe the truck works slow
  • Posted 27 Apr 2013 05:01
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Deborah Baker Deborah Baker
