does not power up
Having problems with no start up, battery displays turns on but does not stay on, changed controller, contactor, connector plugs. Checked for shorted conductor cable all ok, need help. Thanks
  • Posted 24 Apr 2013 07:39
  • By All Lift Tech
  • joined 3 Oct'10 - 57 messages
What is the battery voltage?
Connect a meter, turn the lift on, and watch the meter.
  • Posted 27 Apr 2013 13:14
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
man, are you checking any of these parts or just replacing them? The diode blocks are not what i was talking about. there is a diode on the contactor coil.. physically on the terminals of the contactor coil.
does the contactor close then open immediatly? or not at all?
  • Posted 25 Apr 2013 07:49
  • By stam
found CAN fault by connecting Curtis controller, don't have manual
  • Posted 25 Apr 2013 05:14
  • By All Lift Tech
No luck replaced ed switches and diode blocks
  • Posted 25 Apr 2013 02:11
  • By All Lift Tech
Thanks for the tip stam. will update later
  • Posted 24 Apr 2013 08:26
  • By All Lift Tech
if all the epo circuit is ok, check the diode on the line contactor, make sure it is not giving the coil a dead short. it being on backwards can simulate this.
  • Posted 24 Apr 2013 08:05
  • By stam
Sue Tomic Sue Tomic
Yale Lift Truck Technologies
Sue Tomic Sue Tomic
