Mitsubishi FG20N 2006
We have been asked to look at a Mitsi FG20N that has had a no spark problem and the customer has already had the loom and ECM replaced by another company which has still not resolved the problem. Has anyone got any ideas before we have a look at it?
  • Posted 3 Apr 2013 00:33
  • By danny_k
could also be a bad relay or fuse box, have seen quite a few of those cause a no run situation because of the internal connection bars breaking causing an open circuit in the ignition and/or starter circuit
but as was suggested, see what codes it is displaying first if any
  • Posted 3 Apr 2013 20:06
Another possibility would be a bad relay/fuse
  • Posted 3 Apr 2013 07:58
  • Modified 3 Apr 2013 07:58 by poster
  • By kevin_t
Nissan K21/K25 engine so it be showing a code(s) on the display would be a start to see what codes are present....possibilities include cam and crank sensors but that's just a WAG with out more info
  • Posted 3 Apr 2013 02:10
  • By kevin_t
Muncie, IN, United States
