Jungheinrich Fork Lift Fault
Junghienrich EFG-VAC 20sp with lift fault coming up, battery percentage coming up with o%, but is fully charged, tilt and side shift work fine, but no lift, any light on this problem would be greatly app.
  • Posted 28 Mar 2013 07:55
  • By simon_s
  • joined 28 Mar'13 - 2 messages
  • Victoria, Australia
Thanks from down under, an Aussie in trouble
Lisa Unit?? BDI, can you explain further on these two units, ie location reset procedure, thanks so far for your help, i thought that it would lock the lif out wit low battery voltage.
  • Posted 28 Mar 2013 10:51
  • By simon_s
The lift is locked out because the battery is either still flat or it thinks it's still flat and it is not seeing the threshold voltage to re set the BDI. Try plugging the charger in for 5-10 mins and then up plug the charger and plug the battery straight in to see if it re sets the BDI. If this oes not work you may need to re set the the lift lock out % setting with the LISA unit or the BDI may be faulty or you have a battery fault.
  • Posted 28 Mar 2013 10:13
  • By danny_k
Muncie, IN, United States
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Toyota 8FG25
USD1
Toyota 8FG25
