Truck got wet, 2 blown resistors and Code 5J 5G Help!
As per the title. Happy to send gifts for help!
If we can't fix it, its going to the scrap yard next week :(
Was great, left outside in the rain for a week. Staff powered it up and now we have 2 dead resistors on the fuse/relay board (since replaced) and stuck with a code 5J 5G.
What do the codes mean? many thanks!
  • Posted 10 Mar 2013 23:32
  • Modified 10 Mar 2013 23:38 by poster
  • By Meowmix
  • joined 17 Feb'13 - 10 messages
  • Queensland, Australia
Showing items 1 - 18 of 18 results.
I`m assuming this is a 7400?
send model and ser
56 comes up from a bad battery. under load, use a voltmeter with min-max to capture how low the voltage goes under load. Check this first
  • Posted 23 Mar 2014 22:38
  • By EasiTek
Can somebody help me decoding errors 53 and 56 please??
  • Posted 23 Mar 2014 01:21
  • By luis_y
  • joined 24 Oct'04 - 29 messages
  • Lima, Peru
Hi
electrotech thanks heaps for the offer! I'm waiting for a replacement VM to come available so I can go from there. Without the service manual its pretty hard to work on these!
Cheers
  • Posted 19 May 2013 18:39
  • By Meowmix
hi there meowmix I have four of these units in Victoria which I have not had any problems with if you need some info glad to help
  • Posted 13 May 2013 19:42
  • By electrotech
  • joined 15 Apr'13 - 66 messages
  • Victoria, Australia
Reach for the sky
The K4 relay is the only one not powered by the key...has constant power, but gets negative from the VM. I'm sure your VM is damaged and internally shorted. Moisture and voltage are a bad combination!
  • Posted 25 Apr 2013 11:35
  • By EasiTek
Hi Everyone,
New relay card arrived. Looks a whole lot better than the old one!
Relay K4 is always latched regardless of the key position. As soon as the battery is connected you'll get error FN. As in the VM is always on.
With Relay K4 plugged in and the key turned to 'on' no other relay will latch and the usual 5J 5G error comes up.
Unplug relay K4... Turn the key to on, all other 3 relays latch and the truck starts up fine. Has drive, lift, steer all good. It does have an error 61 comming up.
It did have an error 8L however after a few minutes use it has disappeared and hasn't came back.
Stepping on the deadman the brake on the top of the drive motor clicks and all is good. About 20 seconds of being on the deadman the brake will start clicking on and off non-stop, just click click click...
Jumping the pins on the relay K4 socket and that brake click click click issue is gone. (error 61 is still there). However I can't leave the relay jumped as when they key is turned off, it goes back to the 'FN' error.
I'm assuming something is wrong with the cirucit for the K4 relay coil. As with that relay plugged in, no other relay can start.
Checked the VM for burned pins, all looks o.k.
Everything else seems to be all working! Any ideas?
Many thanks!
  • Posted 18 Apr 2013 23:02
  • Modified 18 Apr 2013 23:36 by poster
  • By Meowmix
1022159/003 was superseded by 1022159/004 and the 004 by 005, either will work. Thanks have a great day.
  • Posted 26 Mar 2013 07:13
  • By patrick_b
  • joined 10 Dec'11 - 30 messages
  • Alberta, Canada
hehe G'day to all.
Just to set things right I might see if I can replace the fuse/relay card.
The card I have is a 1022159/003. There seems to be a few of the 1022159/004 and 1022159/005 for sale. The 004 appears to look identical. Are they compatible boards?
Been going through the connections cleaning them up, takes such a long time however I've come this far, I'd hate to give up now!
patrick_b and raytech thanks for the help so far!
  • Posted 25 Mar 2013 22:42
  • Modified 25 Mar 2013 22:43 by poster
  • By Meowmix
8L you have to worry about. number one cause of 8L is wire broken at brake unit, where it twists. K2 replay pins burned....thats the key on positive power supply. Last is the pin at the VM. Thats the brake negative output power. It will smoke. JPC20-14 terminals burn. You dont have to replace the harness and VM. Open VM and add jumper wire to JPC20-14 and route to harness. Lots of power in this ckt. K2 relay takes a lot of heat.
PUT new relays if you didnt already. That relay card will cause all kinds of problems. It has to be 100%!!!! As long as you have corroded or burned terminals, nothing will work.Code 61 can be caused by a bad or mis-adjusted prop valve
I have brand new trucks from the factory giving codes from bad connections at the VM. So any moisture or corrosion will make things code out.
G-day!
  • Posted 24 Mar 2013 03:45
  • By EasiTek
Code FN - Relays Did Not Open at
Power Of
Code 61 - Mast Switch #1 Not
Crossed
Code 8L - Brake Feedback
Current Out-of-Range
Lets start with code fn which is related to k4 staying closed, B+ comes from the vehicle manager to the keyswitch, then too the relaycard and to the coil of the k4 relay, inspect the keyswitch for leakage when off, terminal 10 is the power input to the relay card from the keyswitch, you either have leakage across the keyswitch or still have issues with the fuse/relay card.
Mast switch #1, either a d-switch or a prox switch on the mast for when the carrage maxes out and the mast starts to stage, inspect it, but also maybe the encoder.
Brake feedback, does the brake release? measure the resistance of the coil, inspect for corrosion on the connectors/wires.
You should make a post in the technical section to see if someone can send you a manual, unfortinitly mine is paper so i cannot, that way you can have a wiring diagram in front of you, sometimes people have pdf manuals they are willing to send via e mail.
  • Posted 21 Mar 2013 08:05
  • By patrick_b
  • Alberta, Canada
Well we have progress!
Amps now power up. Have steering, movement and lift all working!
However we now have error 61. After using for a few minutes we also get error 8L. What are these in relation to?
Relay K4 is staying latched even after the key is turned off. Its latched as soon as there is power to the truck. K4 seems to power up the VM and with the key in the off position it starts up to error FN. With the key on it seems ok, error 61 is there but error 8L is not.
The nightmare continues
Thanks for the help so far!
  • Posted 20 Mar 2013 22:09
  • By Meowmix
I didn't get a chance to play with it end of the week. Some one boxed it in with some old pallets and a dead crown truck.
Will be looking at it hopefully tuesday.
The VM had a small lithium battery loose in the housing, it appears to have came out of its holder. Its completely dead, I'm assuming thats just to keep the clock running?
I removed the plastic from the relay sockets and it appears that K3 and K2 were very heavilly oxidised. K3 has no connection to the track arround it. I've since soldered it up hopefully will show a tad more life now.
We have 2 of the older easi 30/40 trucks so I'm swapping the relays from them.
When you first key the truck on K4 latches and then when the key is turned off K4 stays active. Any idea there?
Thanks to all for the great help so far! I'd really hate to send this truck to scrap.
  • Posted 17 Mar 2013 22:27
  • By Meowmix
from left to right, the last relay on right is not required. Cold storage ckt only. The second from the left is most important. Remove it and check its female pins very carefully. Remove the others and compare them. Often, they female connections burn and wont carry current. A local electronics store can replace the relay sockets and test the board. Any discoloration in the female pins will cause those codes. Pins at the Vehicle manager can spike and cause problems. Remove all plugs from the VM and dry the sockets with electrical cleaner. Make sure all electrical components are dry...remove them and bring them in to the heat. The operator display may be shorted as well...Start with this >>>and make sure a cat is not hiding in there...:)
  • Posted 15 Mar 2013 11:29
  • By EasiTek
Try swaping relays around, possible the tips of K3 are oxidized causing the low B+ voltage. But the problem is that you are not getting B+ at the trac and drive amps when K3 is energized/on. Power goes through Fuse 5 on the relay card, to K3 when it is on/energied and to the trac and lift amps terminal 1 B+, which wakes the amps up. Veryify you have 36volts/battery voltage across fuse 5 on the relay card, with everything connected and the unit powered up, but you should since fuse 5 also powers the key switch.
If their was a short in one of the amps in the B + cicruit it should be blowing fuse 5, they show a thermistor in the wiring diagram on a lot of cicruits on the relay card, but none on the B+ circuit to the trac and lift amps, otherwise i would say that is why you are not getting full power at the amps. Their is still a issue with the relay card, you could try making a small jumper with a 10-15 amp fuse direct from the battery to the B+ terminal at the lift and trac amps, with the unit key'd up the leds, should light up on the amps. Look very closely at the K3 relay/terminals on the relay card/inspect the b + wires between the relay card and the amps.
  • Posted 14 Mar 2013 09:04
  • Modified 14 Mar 2013 09:14 by poster
  • By patrick_b
  • Alberta, Canada
Once again, thanks heaps for the help.
I could only locate 2 amps in the truck. One below the VM and one on the back corner left hand side behind the lift motor.
They do have LED indicators on them not lit.
Amp behind the lift motor was at 2.0V at B+
Amp below the VM was at 5.1V at B+
After unplugging the amps and keying on a few times still no lights on the amps, now occasionally getting error code FN and G4.
If the last 2 relays are removed then stepping on the deadman will make the middle contactor click on and the steering work.
  • Posted 13 Mar 2013 21:03
  • Modified 13 Mar 2013 21:03 by poster
  • By Meowmix
Yea, by amps i mean the ac inverters for the drive and lift, they should have a little led on them that will blink when powered up, i know the curtis ones do, but the 7400 use another style amp, but i think they still have the led on them, and i don't have a truck in front of me to look at and see.
Is your truck electric steer? I know its not coding out for the steer amp, but unplug the steer amp (behind the lift pump motor) and key the truck up and see what codes you get, i know its not showing a code for it, but possible that its shorted causing the other amps not to power up. (also see if when the steer amp is unpluged do the lift and trac amp led's light up) I would send you a manual but i only have a paper book, B+ is terminal number one on the lift and trac amps small wire connector, check to make sure you are getting 36v at that terminal when k3 relay is closed during startup. It really sounds like a power issue to the amps, or both amps are fried due to moisture, but the traction and lift amps are sealed fairly well and don't seem to have major moisture issues on the 7400's, unless the whole system or bad relay card sent a nasty power spike through the truck. If you have battery voltage at the lift and track amps at terminal 1, and the led's are not lighting up its pretty safe to say they are fried.
  • Posted 13 Mar 2013 07:11
  • By patrick_b
  • Alberta, Canada
I assume when you say amps you mean the AC inverter units?
I didnt see any lights on any of them.
All fuses are ok. After replacing the blown 180ohm 1watt (R1) all the relays now close on the board.
The board I'm just replacing the parts on. Raymond trucks in Australia are very rare and you can't buy parts from the local toyota dealer. (and if you did, the replacement part would cost more than the value of the whole truck).
Thanks heaps for replying!
  • Posted 12 Mar 2013 23:13
  • By Meowmix
Code 5G - No Communications
Received from TPA
The VM has received no
communication from the TPA.
Code 5J - No Communications
Received from LPA (AC Lift)
communication from the LPA.
Are the led's on the amps lighting up? did you change the whole fuse board or just replace parts? All the main fuses are ok i assume? When you key the truck up do the relays close? K3 powers the amps.
  • Posted 12 Mar 2013 07:51
  • By patrick_b
  • Alberta, Canada
Crown CG33P5
Airman ENCL045
REPOWERTEK Inc
