Toyota 6BRU18 Code 61 issue.
We have a Toyota 6BRU18 S/N 31243 that is showing a code 61 and I have been told that code 59 has also showed up. We do not have any info for this truck so I am kind of poking around in the dark as far as trouble shooting the problem. Anyone with any code info or schematics would be of great help.
  • Posted 7 Mar 2013 13:30
  • By RAFARMER
  • joined 17 Jan'12 - 153 messages
rafarmerjr@gmail.com
Check on thread Toyota 8BRU23 Fault F1 ect. may offer some insight. although not an AC truck looks like the 6BRU uses the same dash watchdog.
  • Posted 21 Sep 2018 00:03
  • By tom_p
  • Alberta, Canada
I have the same problem with my 7bru18. Code 61 and the truck shuts down. So it the wiring harness on the steer controller with 4 wires, steer motor brushes.
  • Posted 20 Sep 2018 08:32
  • By JoeMar
  • joined 18 Oct'16 - 14 messages
please, need help with code 59 and 41. what it means?
  • Posted 10 Jan 2018 06:12
  • By antonio_r
  • joined 10 Jan'18 - 1 message
  • Baja California, Mexico
hello if you are still having this issue change the steer motor or change the steer motor brushes, run into this issue all the time
  • Posted 9 Sep 2015 07:57
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
hey
i have a unit also throwing a code 61 sometimes it will run for awhile and sometimes it will only go a few feet and shut down........... just wondering if you can share any info for repair or let me know what fixed your unit for this problem?
thanks chad
  • Posted 8 Jul 2015 06:52
  • By chad_b
  • joined 8 Jul'15 - 1 message
  • Iowa, United States
Pull the left cover while it is coding. What are the leds doing? The wires may lokk fine but may have intermittant issues.
  • Posted 15 May 2015 12:22
  • By rogeriwt
I have a 6BRU18 and it has gotten to the point that it will not move more than a few feet without throwing code 61. A service man from the Toyota forklift dealer couldn't figure it out and wanted me to bring it into the service center but I am unwilling to do so because if they cant fix it on site then what makes me confident they can fix it at all. After reading your post I checked the 4 large lead plug and all seems good. Do you have any other suggestions?
  • Posted 14 May 2015 07:01
  • Modified 14 May 2015 07:01 by poster
  • By old33auto
  • joined 14 May'15 - 1 message
  • Oklahoma, United States
The leds on the controller will show codes when the truck is coding out only. You may want to try the big connector with the 4 wires in it. I have had issues with them loosing up on the connections and creating huge problems.
  • Posted 24 Dec 2013 04:11
  • By rogeriwt
no codes from controller and will still fault at times.
  • Posted 19 Dec 2013 02:41
  • By phil_r
  • joined 9 Apr'10 - 21 messages
  • Illinois, United States
It is a steer error. Pull the cover on the right side of the drivers compartment. The steer controller is in there and there are leds that also give you codes.
  • Posted 7 Aug 2013 09:55
  • By rogeriwt
Have an unit doing the same thing. Will work fine for several days and then start throwing code 61. I believe its in the steering.
  • Posted 6 Aug 2013 00:35
  • By phil_r
Taylor X550M
UN Forklift FGL35T
Combilift Ltd
Sue Tomic Sue Tomic
Taylor X550M
UN Forklift FGL35T
