Help with Yale MPB040E electric pallet jack & alarm AL01-Need repair manual
We have a Yale MPB040E electric pallet jack. The handle was damaged at one point and we ordered a replacement handle. We put the pallet jack on a pallet and placed it up high and out of our way until we had time to work on it. When we had time we pulled it down and noticed that now the batteries were dead. Ordered batteries and replaced and tried the jack. No go! The unit powers up and 4 green lights power on with what looks like a slide rule (?) and shows EP107, then red light flashes and AL01 appears. Any help would be greatly appreciated! Where can we get a service manual?
  • Posted 6 Feb 2013 01:19
  • By JerryMedical
  • joined 6 Feb'13 - 2 messages
  • Virginia, United States
Hi all, I have an electric YALE MPB040-E and I would like to know if someone could help me set up the 'hand' (movement control)
  • Posted 25 Jul 2017 12:28
  • By ezequiel_a
  • joined 25 Jul'17 - 4 messages
  • Buenos Aires, Argentina
Hi, i have a mpb040 electric pallet, it shows al13 on the controller, the provider has no clue or manual of it, Need help, thanks in advance
  • Posted 23 Jul 2015 22:32
  • By Antonio_Velazco
  • joined 23 Jul'15 - 1 message
  • Lima, Peru
Thank you for your response! We need the schematic diagrams for this unit to make sure it is connected properly. Where can we get the diagrams and or repair manual? Thank you in advance!
  • Posted 21 Feb 2013 01:14
  • By JerryMedical
AL01, 1 flash.
Condition- Connection/communication error between control card and traction motor.
Truck response- traction and hoist functions diabled.
Possible cause and test proceedures
1) Loose or damaged elec. connection between control card and controller. Verify connection at controller, verify wire harness connection at base of steer handle, verify connection at control card.
2) Damaged or defective control card.
Measure voltage at pin 5, connector C on the controller. W/ control card disconnected, this should be about 12V; w/ the card connected, it should be about 3 - 9V. A reading of 0V or 12V w/ the card connected means that the card or connector pins are damaged.
I would double check where you connected the handle.
Γιάννης από την Σπάρτη
  • Posted 6 Feb 2013 21:16
  • By 7777
