Service manual CAT 2EC25
Hello I am doing some work on this forklift and need some help understanding it. Any manuals would be greatly appreciated.
  • Posted 19 Jan 2013 07:37
  • By digitalpnk
  • joined 2 Sep'11 - 24 messages
email me : cprf4u@gmail.com
well yeah a serial number might help but depending on which contol system this truck has the code means the following:
EV100ZX system - code 02 - Forward switch closed on initial start
problem could be bad directional switch, bad wiring associated with F/R switch, short circuit between TB3 and TB5 or a defective logic card.
I will assume this is not a Microcommand system on this truck due to the code being displayed but the microcommand code for directional input error is:
Micro Command System - display E - Directional switch circuit defect. Possible causes could be directional switch, wiring to directional seat defect, logics defect.
Code 2 does not exist in microcommand system far as i can see.
check your directional switch inputs and associated wiring.
Hope this helps
  • Posted 22 Jan 2013 21:52
  • Modified 22 Jan 2013 21:59 by poster
You have a serial number and year?
  • Posted 22 Jan 2013 19:59
  • Modified 22 Jan 2013 20:17 by poster
  • By kmj_f
  • joined 12 Jan'13 - 31 messages
  • COLOMBO, Sri Lanka
we need a SN to be sure we are speaking of the correct truck?
  • Posted 22 Jan 2013 12:39
Have code 02, anyone knows what it means ?
  • Posted 22 Jan 2013 06:59
  • By digitalpnk
GemOne
