Doosan GC15S-5 Code 292
SN: PI-00310
Anyone have info on code 292 on a woodward fuel system in this doosan,looked thru all the info i have and couldnt find this code,found 291 which has to do with the Throttle Position sensor,but nothing on this code.
Truck is running fine with no problems,cleared the code and didnt come back today,will check it again tomorrow but wondered what this code means???
Anyone have a PDF for this truck they could share??
  • Posted 15 Jan 2013 07:30
  • Modified 15 Jan 2013 07:40 by poster
  • By kevin_t
Found out that code 292 also has to do with the TPsensors,is only in trucks with version 12 software or newer i guess from my contacts info,same troubleshooting as code 291. Truck still has a intermittant code can clear it and after a few days it comes back again as does code 291 sometimes,truck runs fine with no problems,just clear the codes and wait a few days and they/it comes back again
  • Posted 31 Jan 2013 09:46
  • By kevin_t
could be related to single backfire to inlet pipe. This affects electronic throtle operation and alarm comes ON. If this the case I would consider other LPG supplier (BTW the mixture for this model should be 90% propane and 10% butane)
  • Posted 31 Jan 2013 08:47
  • By sebastian_z
  • joined 21 Feb'07 - 13 messages
  • Lodzkie, Poland
Simon: My email address is in my profile,click on my name and it will show there,thank you
  • Posted 16 Jan 2013 06:39
  • By kevin_t
We've had a few of these machines that throw spurious error codes which never re-occur after clearing but it is worth checking the wiring to the mixer/throttle body. I have pdf's if you want to pass on your addresses.
  • Posted 16 Jan 2013 05:23
  • Modified 16 Jan 2013 05:24 by poster
  • By simon_k
  • joined 31 Oct'04 - 147 messages
  • Devon, United Kingdom
I had the same problem as well. No info regarding 292. Please pass any info on to me also, thanks.
  • Posted 15 Jan 2013 14:02
  • By MacGyver
  • joined 28 Apr'10 - 24 messages
  • Wisconsin, United States
namaha01@hotmail.com
Nagano NUL120-6
Kalmar-Ac P100CXD
Nagano NUL120-6
Kalmar-Ac P100CXD
