HI there
Sorry I dont have the serial number to hand but I have a Jungheinrich EFG truck, early 2000. Its driving and hydraulics working fine, but just bleeping with an error 126.
Does anyone know what this error might be as my list does not show the code.
Regards
Thank You Everyone
It was a faulty lift pot, reading erratic.
Thank you
Will look at hopefully friday.
Regards
Hi electrodrive, just to confirm, error 126 is error 26 which is normally a faulty lift pot, or broken cable to lift pot.
Hi elektrodrive
For info. Jungheinrich first generation errorcodes only numbers to 99. Higher numbers is like: 126= 26 110=10 and so on. 126 is then: Broken cable for lift-potentiometer or broken joystick/multipilot/solopilot. Any further questions just write.
Best regards, Max
Thanks You
I will get the serial next time I am onsite. If i could access the dash system I would have tried resetting parameters. I usually can plug in my LISA displays and use them on most truck, however the connector on the back of this dash display on the truck is a D pin connector and I dont know the wiring otherwise could have built a loom to plug in my displays to adjust. So if its pot related and requires adjustment then Im stuck :)
I think Lift potentiometer.
hello Elektrodrive
Can you find serial of the truck and is it error or info that is show.
I also cant see what is error 126 and if everything works fine it is probably some warning or info.
I can try to help only with serial.Thanks
