Toyota 7bru18 error code
Toyota 7bru18 error code "EPO?"
error code "EPO?" ????
some sort of rare model, the display is red.
Battery Status LED Indicator.
looking for manual, any help.
  • Posted 28 Dec 2012 08:03
  • By alexandr_k
  • joined 6 Dec'11 - 197 messages
  • Ukraine, Ukraine
where they are located, these "Mast Switch 1" and " Limit Switches". like all it looked, did not find?
  • Posted 5 Jan 2013 03:59
  • By alexandr_k
  • Ukraine, Ukraine
71 Mast Switch 1 Not Crossed
This code is displayed if the Display Card detects that
while lifting at 80% or more lift speed for longer than 7
seconds, Mast Switch 1 has not turned OFF.
02 Limit Switches Do Not Agree
This code is displayed if Mast Switch 1 and the Staging
Switch are activated out of order.
  • Posted 4 Jan 2013 08:13
  • By kevin_t
Hi all
You were right about the emergency stop button,
thank you it was really closed,
but after it is repaired,
forklift more
steering-ok
turn-ok
hydraulics-not working
after turning the key on - code 71
and after-code 02
looking for manual or any help.
  • Posted 4 Jan 2013 03:50
  • By alexandr_k
  • Ukraine, Ukraine
There should be a red round button with arrows on it on the dash by the display, that is the EPO. You may to twist and it will pup up. The messages are all related to that.
Happy New Year to you too.
  • Posted 30 Dec 2012 08:18
  • By rogeriwt
added came another message " turn key off/on to reset travel and lift disabled..." but after on and off
everything remains the same. battery in good order. This reach truck - that model for the U.S.
the models to ordinary description I have.
after the weekend I will write continued,
you all a happy new year.
  • Posted 30 Dec 2012 05:32
  • Modified 30 Dec 2012 05:48 by poster
  • By alexandr_k
  • Ukraine, Ukraine
Radon is correct. EPO is emergency power off switch is turned on or there is a wiring issue to it. I would start with the switch first.
  • Posted 29 Dec 2012 03:36
  • By rogeriwt
greetings
I never encountered such damage, internal electronic display shoot, but before it goes in this direction make sure the battery in ok condition, do not drop the V and A.
  • Posted 29 Dec 2012 00:24
  • By moeklis_m
  • joined 18 Nov'12 - 7 messages
  • bekasi, Indonesia
moeklis ,indonesia!
I believe its same as Raymond , Emergency Power Off. Is truck dead, no functions, check what i call emergency disconnect switch, check red button on dash make sure switch didn't come disconnected make sure its pulled up.
  • Posted 28 Dec 2012 08:45
  • Modified 28 Dec 2012 08:47 by poster
  • By radon
  • joined 28 Sep'11 - 62 messages
Muncie, IN, United States
