Code 54
SAS Light is on at the dash. Throwing code #54. What does this code mean. What should I look for?
  • Posted 21 Dec 2012 02:23
  • By ATK1
  • joined 27 Jan'12 - 74 messages
  • South Dakota, United States
allenk@ntlifts.com
Not sure,I don't work on a lot of toyotas,but if that is the active code then I would address it first
  • Posted 21 Dec 2012 02:58
  • By kevin_t
This morning the unit was running and operating correctly with the light on. Now the unit will not start. Code 54 Swing solenoid abnormality wouldn't prevent the unit from starting would it?
Thanks.
  • Posted 21 Dec 2012 02:56
  • By ATK1
allenk@ntlifts.com
54
Check your solenoid for the SAS cylinder on the steer axle
  • Posted 21 Dec 2012 02:46
  • By kevin_t
ROYPOW
JCB 533-105
Manitou M50-4
