Won't drive while steering
When forks are above 24" unit will not drive while steering to the left or the right. Already replaced both steering switches and the two lower mast switches. Any ideas on where to go from here.
  • Posted 19 Dec 2012 02:38
  • By ATK1
  • joined 27 Jan'12 - 74 messages
  • South Dakota, United States
allenk@ntlifts.com
alot of orderpickers are and can be configured this way if operating in an aisle to keep the truck from driving when steering off center. I believe its called a 10 degree cutout.
It is an option so not ALL trucks have this, it seems yours does.
I'm sure there is a way to turn this off or disable it but would you really want to?
Check the dash panel to see if there are any enable/disable switches, one may be there for a manual disable mode when working out of the racks. Otherwise there may be some issue with the circuit when below 24".
  • Posted 20 Dec 2012 22:11
  • Modified 20 Dec 2012 22:12 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Home Depot trucks are configured this way. If I remember correctly, you need the hand held that plugs into the Curtis controller to change the configuration on this.
  • Posted 20 Dec 2012 02:11
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Can I get to that configuration through the Curtis Controller? Is that something I can get to without the handset that attaches to the card?
  • Posted 20 Dec 2012 00:19
  • By ATK1
allenk@ntlifts.com
Sounds like a configuration in the menu
There is a setting to slow/stop the truck when elevated and not going straight.
  • Posted 19 Dec 2012 14:30
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Muncie, IN, United States
Komatsu FD25T17
SMV (Konecranes) 4632CC5
