Raymond easi opc30tt
Code 45. Pc contactor not pulling in at all. Any clues? Has new contactor. Couldnt get into the maintenance screen due to not having the pass code for the truck. The pc sense line has to have a contactor close to get the voltage it needs so don't think it's that. I'm leaning towards a new VFC. But wiuld like others opinions. Thanks.
  • Posted 18 Dec 2012 09:23
  • By marvin_g
  • joined 21 Feb'11 - 25 messages
  • Kentucky, United States
I wouldn't be so fast as to condemn the vfc its to expensive!! First check to make sure your getting battery volts to jps14-5 emergency switch input , then jps26-1. If there good, look at coil driver card , it maybe bad I don't know if you have any way to check jps11-3 for controller neg. but try to.check it. Be sure and check fu11 fuse too.
  • Posted 28 Dec 2012 04:04
  • By radon
  • joined 28 Sep'11 - 62 messages
