H20E 1966 couple questions.....
I have a couple questions about a 1966 H20E 3 wheeler with a Y112 engine.
1. On the floor board, right side, there is a T handle pull cable.
It is associated with the brake system.....
What does it do and how does it work??
2. The hydraulic filter cartridge is Hyster P/N 236090 and
the gasket is 236088.
Can anyone cross the Hyster numbers to a more common brand of replacement cartridge number?
Baldwin? Purolator? Fram?
Thank You!
dk
  • Posted 17 Dec 2012 03:15
  • Modified 17 Dec 2012 03:16 by poster
  • By dkmc
  • joined 18 Oct'09 - 48 messages
Yes, that's exactly how it works.
It was awkward when I last tried to reconnect the chain with the FL tipped up on a steep angle with the engine idling in gear to keep the chain as slack as possible...... HA!
It was not slack enough, I couldn't re-connect it but I want to and I need the parking brake functioning.
Maybe that T handle is the key to success with this problem.
  • Posted 17 Dec 2012 04:43
  • By dkmc
I can't remember exactly how that worked. Hydraulic pressure was used. Starting it may cause the chain to get slack and then it goes tight when shut off.
edit, I guess you have to put it in drive too to get the chain slack. The T handle should do it.
  • Posted 17 Dec 2012 04:36
  • Modified 17 Dec 2012 04:43 by poster
Thank you,
There is a small chain under the unit that is supposed to connect to the park brake linkage. It is unhooked.
I am trying to figure out how to get that chain slack enough to re-connect it. Perhaps that handle is the key
  • Posted 17 Dec 2012 04:29
  • By dkmc
That has a automatic parking brake that comes on when the machine is in "park" or not running. If you need to move it, and it won't start, the T handle releases the brake.
  • Posted 17 Dec 2012 04:22
Thank you, yes need the gasket......it is leaking a bit...
  • Posted 17 Dec 2012 03:44
  • By dkmc
236090 will cross over to a NAPA filter#1092,might come with the gasket
  • Posted 17 Dec 2012 03:33
  • By kevin_t
VETTER Forks, Inc.
Sue Tomic Sue Tomic
