JUNGHEINRICH EFG/DF18
Hello,
On a Jungheinrich EFG/DF18 sn;80378844 we had to replace the gears of the rear steering axle. Can someone tell me what the type of oil we have to fill it with? I think it is SAE80W-90 but to be on the safe side.
Many thanks
Marc b
  • Posted 13 Dec 2012 01:34
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Hey Swoop; you're write with your explenation. I've received a drawing and we had to install it with lithium grease.
Kind regards
marc b
  • Posted 14 Dec 2012 17:39
  • By marc_b
  • ANTWERP, Belgium
marc
you best be sure what you have in there before just throwing any ole fluid in it.
jungheinrich doesnt use regular oil in most cases
they use mineral oil type fluids for hydraulic oil and brake fluids and in gearbox fluids for transmissions etc they use Shell Spirax MA80W.
If you have the owner/operator manual for this unit it should have a breakdown of what fluids go in this unit in the maintenance section. In some cases mixing oil's would be a bad idea. There are some folks that may tell you it wont hurt to do it but trust me, in the long run you dont want to have to deal with the damage it might cause. Jungheinrich is like linde when it comes to thier oils, they are specifically designed and in most cases unique to thier products.
  • Posted 13 Dec 2012 21:38
Hey Joram,
Thanks for the information
many thanks
marc b
  • Posted 13 Dec 2012 03:35
  • By marc_b
  • ANTWERP, Belgium
Cilinder steering axle. SAE10W. uses the same oil as the hydraulic system.
Check you mail.
  • Posted 13 Dec 2012 03:12
  • By joram_s
  • joined 5 Feb'11 - 117 messages
  • madrid, Spain
Email soyjoram@gmaildotcom
Hangcha FLDCXT160
Toyota 02-8FD30
Muncie, IN, United States
Deborah Baker Deborah Baker
MAXAM Tire, Inc.
