Yale HtEncErr
model 0S030ECN24TE089
S/N C801N02550Z
I need to check the encoder at top of mast and wiring back to curtis controller. any info would be helpful
anyone have schematic??
Thanks,
  • Posted 7 Dec 2012 02:44
  • Modified 7 Dec 2012 11:24 by poster
  • By Parkway
  • joined 21 Jan'10 - 83 messages
pkwyls AT verizon DOT net
ok its showing the limit switch turning on and off, this means the system is seeing it turn on and off so i wouldnt think this is the problem.
Does the handset have capability to see throttle input?
check and see if it is operating correctly, 0% to 100%?
in both directions
  • Posted 13 Dec 2012 21:51
  • Modified 13 Dec 2012 21:52 by poster
Drive problem now! Runng slow, like its past the limit switch or.
Pot is not turned all the way "creeping"
Showing no codes on display.
has a limit eye, handset showed it turning on and off
When lifting and lowering
  • Posted 13 Dec 2012 00:37
  • By Parkway
no codes?
  • Posted 12 Dec 2012 21:49
Replaced lift motor, no codes and lifts fine.
Now it runs/drives slow! any ideas??
Guess I'm going to have to buy a book on this one
  • Posted 12 Dec 2012 13:06
  • By Parkway
incorrect battery or low battery or bad battery can trigger this code also
  • Posted 10 Dec 2012 07:07
  • Modified 10 Dec 2012 07:08 by poster
That was easy, Bad lift motor will cause this code
  • Posted 8 Dec 2012 10:30
  • By Parkway
Deborah Baker Deborah Baker
Aichi SR10C1SM
Aichi SR18A
Aichi SR10C1SM
Aichi SR18A
Hawker Powersource, Inc.
Muncie, IN, United States
