Hyster Lift and tilt problem
Model J35XMT S/N C160H02707T
I need wiring diagram and schamatics
machine has a card at lift, tilt and side shift.
slow lift and will not tilt down. i think this card in bad,
but would like to run some voltage tests
anyone have some info on this lift
  • Posted 30 Nov 2012 07:34
  • By Parkway
  • joined 21 Jan'10 - 83 messages
pkwyls AT verizon DOT net
Your welcome :)
  • Posted 12 Dec 2012 00:29
  • By Jarun
  • joined 30 Nov'12 - 8 messages
  • 03-144, Poland
Jarun, i think you were right. The electirc checked out. Motor & Pump are running both Lo and Hi speeds so it has to be pressure.
  • Posted 7 Dec 2012 02:34
  • By Parkway
Thanks for all the info.
Big thanks to all that emailed
I will run some tests and post what I find
  • Posted 2 Dec 2012 02:18
  • By Parkway
Does it have an EV100 pump controller? and by slow lift do you mean barely moveing?(motor slow)
  • Posted 2 Dec 2012 01:54
  • Modified 2 Dec 2012 01:56 by poster
  • By snowmonkey
  • joined 13 Oct'12 - 36 messages
  • Alberta, Canada
look on you mail.
  • Posted 2 Dec 2012 00:11
  • By michel_v
  • noord holland, Netherlands
It has a Pump controller and a card at the handles not NO/NC Switches. I dont think is getting variation of volts back to pump controller
  • Posted 30 Nov 2012 09:16
  • By Parkway
Hi
I think your problem is in hydraulic parts - in main hydraulic valve - standard in Nacco trucks. Try measure pressure on hydraulic valve. Also You can check voltage with multimeter. Always voltages are the same on all functions. Of course when you have solenoids valve
Regards
Jarun
  • Posted 30 Nov 2012 07:47
  • By Jarun
  • 03-144, Poland
jaro.jaworski@wp.pl
Poland, Torun - Copernicus city
UN Forklift FGL35T
Terberg YT220
