yale
Have code 5.....edited by admin...... Please help.........
Sbaca40@ hot****dot com thanks model # is esco30zan36tf083
  • Posted 21 Nov 2012 00:11
  • Modified 21 Nov 2012 07:37 by administrator
  • By checo
  • joined 12 Feb'11 - 2 messages
Code 5 also applies to the newer AC drive systems, some if not all of the original SRO codes from GE apply to these systems. Good ole GE keeps things good for us.
  • Posted 22 Nov 2012 02:56
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
check your brake switch or the accelerator input (switch if it has one)
anything in the start circuit can trigger this code from a bad switch to bad wiring, defective potentiometer etc
assuming this truck has a GE SX controller, the circuit is on P3 circuit on the controller to the accelerator start switch according to GE. You can find the GE manual for this controller on fsip.biz (flight systems)
  • Posted 21 Nov 2012 22:04
  • Modified 21 Nov 2012 22:09 by poster
Code 5 is a standard GE SRO code for accelerator start switch not closing. This should be the problem.
  • Posted 21 Nov 2012 07:10
  • By LTRM
Deborah Baker Deborah Baker
Toyota 02-8FD30
Manitou MH25-4
