Nissan N01L15U steer fault
Hi i have the above truck,its a 3 wheel electric. It burnt out a drive motor,we replaced it and have now discovered a fault in the steering has caused the original motor to burn out. The truck does not slow the r/h wheel when turning right then it cuts out. I have checked all the micro switches at the steering and they are all ok. Any ideas?
  • Posted 14 Nov 2012 22:44
  • By andrew_p
  • joined 7 Nov'12 - 23 messages
  • Co. Antrim, United Kingdom
Andrew;
A serial number would help ID the changes in the power assist steering you truck has. Do you have the testing procedures for the electric assist steering by using the control module? In the base of the steering wheel gear box, truck's left rear, is a steer torque sensor that has three wires, and on some occasions a flat spot developes on the cam follower that is inside the box. This makes the steering next to impossible to neutrally adjust. The steering chain under the truck's battery can become corroded and cause overloading of the electric assist motor.
  • Posted 17 Nov 2012 10:47
  • By MEngr
  • Missouri, United States
Hi andrew
Have you got an email address so i can send you the manual to assist you
  • Posted 17 Nov 2012 00:32
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
A good engineer is a helpful engineer
Muncie, IN, United States
Kalmar-Ac P100CXD
SMV (Konecranes) 4632CC5
