Seal Kit for CAT GP25K
Hello
Dealing with a CAT GP25K ATB17B114
Can't seem to find correct part numbers for hydraulic control valve seal kits for Lift, Tilt and Aux sections.
purchased several kits even from OEM, but none have the correct size o-rings. Can someone help me identifying such kits? The truck has all original components, so the valves have not been changed.
If someone can help, please let me know correct part numbers for these kits. I would appreciate if at least someone tells me how to identify correct valve assemblies in order to purchase correct kits.
Regards,
OB1
  • Posted 7 Nov 2012 04:18
  • Modified 7 Nov 2012 04:19 by poster
  • By ob1kenobi
  • joined 22 Nov'10 - 153 messages
  • SAN P.SULA, Honduras
Cheers!
Excellent info swoop223
You are a master!
Thanks my friend.
Regards,
OB1
  • Posted 9 Nov 2012 02:45
  • By ob1kenobi
Cheers!
2 different makes of valves on these trucks
Koyaba Valves
inlet cover seal kit 9137210550
tilt valve seal kit 9137210570
lift valve seal kit 9137210560
ATT valve seal kit 9127330150
Shimadzu Valves
inlet cover seal kit 9147301040
tilt valve seal kit 9147301020
lift valve seal kit 9147301010
ATT valve seal kit 9147301030
there should be a tag on the valve assy that has what brand valve it is.
hope this is helpful
  • Posted 9 Nov 2012 00:03
Sorry about that!
AT17B138114
  • Posted 8 Nov 2012 03:59
  • By ob1kenobi
Cheers!
recheck your serial number
that one is no good
should be something like AT17B?????
something like that
  • Posted 7 Nov 2012 09:31
  • Modified 7 Nov 2012 09:31 by poster
Deborah Baker Deborah Baker
