Need Linde Help
Please help! Have an H25T with no Travel or Hydraulics. Reading Error codes T239 & L239, Seat Switch/Wiring problem. Unless I am testing incorrectly the Switch is functional. What else could be the issue. Anyone have Service Manual they can share? Any help would be greatly appreciated.
  • Posted 27 Oct 2012 02:12
  • By RJN8
  • joined 25 Oct'12 - 9 messages
if you need a drawing sent you mail
it is on profile
  • Posted 27 Oct 2012 19:32
  • By michel_v
  • noord holland, Netherlands
Look carefully at the wiring harness next to the chair
  • Posted 27 Oct 2012 19:24
  • By michel_v
Did you check seat signals to LHC module? did you check wires?
should get negative signal in pin 33 of LHC module if seat is unoocupied or negative signal in pin 38 if seat is occupied.
Regards
  • Posted 27 Oct 2012 05:43
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Muncie, IN, United States
