BATTERY CHARGER
Need a battery charger for a lansing linde foer 15.1 that I have aquired - Can anybody tell me the model no. or type i need.Thanks
please email [email address removed]
  • Posted 30 May 2007 07:58
  • By TRACTORMAN
  • joined 30 May'07 - 2 messages
  • \, United Kingdom
ebay is the way.or a secondhand truck dealer. manufacturers cost a fortune and only supply new gear.just make sure that the plugs match up
  • Posted 16 Jun 2007 18:53
  • By kevin_k
fix it right first time
Thanks - Ive just recieved the truck the other day - It is 72 volt ,Which is the cheapest way I can get my hands on a charger ?
  • Posted 16 Jun 2007 05:31
  • By TRACTORMAN
  • \, United Kingdom
foer 15.1 is 72 volt system.most 15.1,s i have seen have 100amp 12 hour charger
  • Posted 16 Jun 2007 05:07
  • By kevin_k
it would really depend on the battery you have installed
u have to match the charger to the amp hour capacity of the battery (assuming the battery is the correct one for the machine)
thats about it
im not sure if its the same in the uk but here there is stampings on the side of the batt that you can figure out its capacity
i say call your local battery dealer and have him match a charger for you
here is some info from the webpage gbbattery com/FAQ
*these are just examples and may not apply to the machine mentioned above
FORMULAS:
Charger Model# Breakdown: Example, Model GB100-3-18-750 = GB brand, 100% rated, 3 phase, 18 cell (36 volt), 750AH (Ampere Hour).
Battery Model# Breakdown: Example, Model 18-125-13 = 18 cells (x2 = 36 volt), 125AH per plate, 13 negative plates.
Calculating AH Capacity: Negative plates per cell - 1, / 2 x AH per plate = AH (Ampere Hour).
Example, 18-125-13: 13 - 1 = 12, / 2 = 6 x 125 = 750AH
Calculating KWH Capacity: AH x Volts (2v per cell) = WH (Watt Hour) / 1000 x.97 (efficiency factor) = KWH (Kilo Watt Hour)
Example, battery model 18-125-13, 36V / 750AH: 750 x 36 = 27,000 / 1000 = 27 x.97 = 26.19KWH.
(13 - 1 = 12 positive plates per cell)
  • Posted 15 Jun 2007 14:17
  • Modified 15 Jun 2007 14:27 by poster
  • By justinm
Must post e mail johndoe at somewhere dot net or bot will kill it.Justin where are you? this ones yours
  • Posted 31 May 2007 12:04
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Maxlion FDR45
Ncn 110TH
Ncn 110TH 2015
