lift motor code 6f
intermittint 6f code lift motor over heated , motor not hot comes and gos ,replace wiring harness from motor to vm. does anyone have the bullitin on that code that talk about the modification to the plug on the vm?thx
gary.....
  • Posted 19 Oct 2012 02:34
  • By SERVICE
  • joined 4 Sep'12 - 2 messages
  • Arizona, United States
When we had this same problem (false 6F code), the bulletin consisted of one each of OEM 1087845 wire harness & 950026 extraction tool. I do not have instructions, but replacement is pretty self explanatory. On a seperate note, if you also get a 6G false code, you will need the dealer to come in & flash the computer to new software version. Hope this helps, that's what fixed ours for these intermittent issues.
  • Posted 19 Oct 2012 04:14
  • By Rodey
  • joined 16 Oct'12 - 21 messages
  • Michigan, United States
