HYSTER
Problem with code 24 off EV100
Somtimes hey come's on the display
end stops with drive.
Put out the truck end start again hey drive again for a long time
End some time's severel seconds !!
Ho nows or has this problem to
kindly regards
john.
john.
  • Posted 27 May 2007 07:23
  • By genjohn
  • joined 4 Feb'07 - 59 messages
  • NB, Netherlands
also check the RB (regen) contactor not conducting or closing when driving (regen picks up when this contactor opens diverting motor power from neg thru the 7 rec)
also an open or loose connection in the motor circuit
its series wound so you can check continuity thru the whole circuit from the 1rec to neg with the batt unplugged and working the fwd or rev and RB moveable tips by hand
also defective 1a (bypass) RB SP or FW can cause this
check for seized or binding contactors
and check the fwd and rev contactors for welded normally open tips
check the control wiring to the rb contactor too
  • Posted 15 Jun 2007 14:42
  • By justinm
Check the F/R contator tips. Probably burnt-up,and need replaced.
  • Posted 27 May 2007 08:51
  • Modified 18 Jun 2007 00:08 by poster
  • By Truck_Tech
  • United States
Linde Material Handling
