Truck starts, then dies immediately
I start the truck and it dies as soon as I move the keyswitch back to run. If I keep the switch in start, it will run (and accelerate). It seems to be losing fuel when it's not in start. Where do I go from here? S/N is 80025 if that helps
  • Posted 19 Sep 2012 06:48
  • By Semperfiguy98
  • joined 19 Sep'12 - 21 messages
Just an fyi that signal wire is shielded and if you crimp the shielding the struck will not start like before.
  • Posted 23 Sep 2012 04:52
  • By rogeriwt
And just in case you ever need to replace the connector and wiring, a replacement pigtail kit can be obtained from Toyota under the part number below.
Pigtail kit for Distributor.....90957-U9011-71
  • Posted 22 Sep 2012 10:48
  • By L1ftmech
  • Tennessee, United States
Ok. I went back today and guess what.. Broken wire at cylindrical plug adjacent to distributor. Crimped female spade terminals on wires and it works fine. Thank you all for your help.
  • Posted 22 Sep 2012 10:16
  • By Semperfiguy98
That makes perfect sense. I will look into that. Does anyone else have any suggestions?
  • Posted 20 Sep 2012 06:11
  • By Semperfiguy98
  • Posted 20 Sep 2012 02:18
  • By Semperfiguy98
Check the wiring that leads to the distributor to see if it has a broken tachometer signal wire.
We had one of these same 7F models that did this and a broken tach signal wire about 12 inches back from the distributor was the problem.
Apparently the 7F models are wired to be able to run without a tach signal in the cranking mode only, but will die immediately when the key is returned to run mode and a tach signal is absent.
  • Posted 20 Sep 2012 00:50
  • By L1ftmech
I was thinking that, too. But when the key is in run the dash lights illuminate. That leads me to believe the key switch is ok. Also, there is a solenoid on top of the regulator with a black wire and a black/blue wire. If I apply 12 volts to the black and blue wire, the truck will run.
  • Posted 20 Sep 2012 00:31
  • By Semperfiguy98
if it was me, I think I would start with a meter on the 'run' position of the key switch, and if it had battery voltage in the right spots, I would then use the meter on the LPG relay...
  • Posted 19 Sep 2012 20:15
The LPG relay is behind the sheet metal behind the left step. Does this truck say ECS on the engine valve cover? If so- I would suspect the distributor needs replacing.
  • Posted 19 Sep 2012 09:43
  • By bbforks
It is an lpg truck. Unfortunately, I'm not very familiar with Toyota lift trucks. Where is the lpg relay located? And is there anything else I should check?
  • Posted 19 Sep 2012 09:25
  • By Semperfiguy98
This a LPG truck? if so check your LPG relay
  • Posted 19 Sep 2012 08:56
  • By kevin_t
Terberg RT403
UN Forklift FD25T-C2JM1
Libiao Robotics
