linde 115 R14
hello
Please help stroller linde 115 Series R14
I have a probelm with the ejection of the mast front back
Sliding it to the very front is moving slowly
rearing back very quickly
which may be damaged
Christopher greets
  • Posted 10 Sep 2012 22:04
  • By krzysztof_k
  • joined 2 Feb'11 - 129 messages
  • śląśk, Poland
there must be a little orange led that light up when sensor gives signal and off when sensor is not aligned with the counting metal strip. Look at the sensors, metal strip and also at the main harness under the battery tray where it is clamp. When you reach in and outthe cable move and can sometimes break one of its wire inside the harness. Good luck
  • Posted 6 Oct 2012 11:20
  • By Dwaive
  • joined 7 Aug'09 - 33 messages
  • Quebec, Canada
Dwaive@hotmail
Montreal, Canada
Dear Sir/Madam
hello iam george from iam looking part forklift linde for my customer
the parts that i need is for forklift linde type E 25 C and for Linde R 16:
1.DC Coverter(Linde E 25 C) Part Number: 7917401281
2.Steering Unit(LINDE R16) part Number: 51615420508
please give me a best offer if you can support for that.thanks for your kindly attention and good cooperation
Best Regards
George Peter
  • Posted 27 Sep 2012 21:08
  • By stillengineer03
  • joined 4 Nov'10 - 47 messages
  • Singapore, Singapore
George Peter
georgepeter03 at gmail dot com
I assume that the thing normally caused by the reach in/out sensors as gc-d advised above, otherwise you have to use the laptop to do calibration for these sensors.
Good luck
Nuna
  • Posted 13 Sep 2012 15:34
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
Hi , check sensors on reach frame and the metal strip on the chassis , check of the sensors read the strip.
  • Posted 13 Sep 2012 01:05
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
If it's 115-03 check, if the valve is properly set (with Pathfinder).
If it's OK, check the valve itself (it's on control valve - on section resposible for the reach).
We encountered two such cases in last year and once it was adjustment issue, another time it was the valve.
  • Posted 13 Sep 2012 00:40
  • Modified 13 Sep 2012 01:03 by poster
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
Mitsubishi Logisnext FD25T5M
Mitsubishi FD200
Mitsubishi FD200
Muncie, IN, United States
