Zapi B1 standby I=high
Hi,
I have a couple of forklifts with a zapi B1 which intermittently give the fault 5 flashes, standby I=high. This can temporarily be solved by turning the Offset and gain potentiometers a bit.
I spoke to a zapi engineer one day and he said there was a modification on this. It should be something with blue and grey potentiometers.
Does anybody know something about this?
regards,
Frits.
  • Posted 6 Sep 2012 17:40
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
Hello Naccho. OK
Best regards, Laci
  • Posted 8 Sep 2012 16:42
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
Hello Laci,
It's possible to send me some information about this issue.
Thanks in advance
Best regards
  • Posted 8 Sep 2012 07:56
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Hello Frits. See your email
Best regards, Laci
  • Posted 8 Sep 2012 04:09
  • By LACI
  • Serbia
Thank you Max.
If it is only the poti's it can be an easy fix. Does anybody know the adjustment procedure or do you need special tools for that?
I prefer fixing myself but maybe your are right and having it fixed is better. Disadvantage is long waiting times. We fixed a lot of B1's ourselves but that is mostly changing mosfets and diodes.
regards,
Frits.
  • Posted 7 Sep 2012 05:27
  • By frits_f
Hi Frits.
I've repaired a lot of B1's both JH and standard. Potentiometers in power part has always been bad on this controller. It is not a big issue to replace poti's but adjustment is a bit tricky. One is so sensitiv that you get the error you have, if it is just a few degrees out of adjustment. Send the controller to ATECH in germany or find your local ZAPI dealer and get a price. They know exactly how to adjust it and then you have some kind of gurantie.
Best regards, MAX
  • Posted 6 Sep 2012 19:57
  • By Fittermax
  • joined 17 Jul'08 - 171 messages
  • Denmark
Libiao Robotics
Libiao Robotics
Muncie, IN, United States
