Yale Dash Code
Can someone please help by telling me what code 524275-4
displayed in the dash of the follwoing truck means:
Model: GC120VXPR
Serial: E818V0254-LC120
Thanks,
OB1
  • Posted 29 Aug 2012 07:15
  • By ob1kenobi
  • joined 22 Nov'10 - 153 messages
  • SAN P.SULA, Honduras
Cheers!
can someone tell me what GFI and PSI OPTION stand for?
  • Posted 19 Jul 2013 05:39
  • By steve_c
  • joined 20 Jul'06 - 43 messages
  • Illinois, United States
Excelent info hysterbrazil! Thanks my friend.
regards,
OB1
  • Posted 30 Aug 2012 01:08
  • By ob1kenobi
TSP Position Sensor OORL (Cont)
CAUSE B - SENSOR SIGNAL OPEN CIRCUIT
PROCEDURE OR ACTION:
1. Ensure truck power is OFF.
2. Disconnect indicated sensor connector.
3. Change DMM to ohms scale. Verify DMM zero reading.
4. At sensor harness connector, measure resistance between sensor signal pin (+) and sensor ground pin ( ).
Is resistance approximately equal to the resistor value shown in applicable schematic?
YES: Go to Cause F.
NO: If resistance measurement is infinite, sensor signal wire has open circuit. Locate and repair/replace open
wire/connection. See Wire Harness Repair 2200 YRM 1128. If resistance measurement is less than 0.5 ohms,
go to Cause C.
CAUSE C - SENSOR SIGNAL SHORTED TO SENSOR GROUND
1. Disconnect indicated sensor connector and VSM/ECU/GCU connector.
2. At the sensor harness connector, measure resistance between sensor signal pin (+) and sensor ground pin ( ).
Is resistance less than 0.5 ohms?
YES: Sensor signal wire is shorted to sensor ground wire. Locate and repair/replace shorted wire/connector.
NO: Go to Cause D.
CAUSE D - SENSOR SIGNAL SHORTED TO FRAME GROUND
1. At the sensor harness connector, measure resistance between sensor signal pin and a clean frame ground on
truck.
YES: Sensor signal wire is shorted to frame ground. Locate and repair/replace shorted wire/connector. See
NO: Go to Cause E.
CAUSE E - SENSOR FAILURE
2. Replace sensor.
NOTE: Do not discard original sensor after removal.
3. Ensure that all connections are completely inserted.
4. Turn truck power ON.
Does reported DTC reoccur?
YES: Reinstall original sensor and go to Cause F. See Electrical System 2200 YRM 1142.
NO: Problem has been corrected. Resume operation. Discard faulty sensor.
Check the Service Manual section in Yale Axcess Online for possible updates and check pertinent Bulletins
Confidential/Proprietary - Do Not Copy or Duplicate 9030-20-125
Diagnostic Trouble Codes Electrical System
CAUSE F - FUNCTIONAL FAILURE IN CONTROLLER
1. Ensure all previous procedures have been completed.
2. Ensure truck power is OFF.
3. Ensure that all connections to the controller are completely inserted.
4. Ensure truck power is OFF for no less than 30 seconds, and then to ON to clear displayed DTC.
YES: Go to Step 5.
NO: Problem corrected. Resume operation.
5. At the DSC, press ENTER to access Main Menu.
6. Scroll to VIEW VERSIONS, press ENTER.
7. Scroll to TRUCK SERIAL NUMBER, press ENTER.
8. View the TRUCK SERIAL NUMBER on the display.
Does the truck serial number on display match serial number on truck nameplate (VSM Only)?
YES: Go to Step 9.
NO: Controller has been substituted from another truck. Replace VSM with VSM that has the correct truck serial
number or obtain new VSM with correct Serial number/ CDF. See Electrical System 2200 YRM 1142.
9. Resident Service Approval Required prior to VSM replacement for Trucks under warranty. Make sure
to indicate the DTC code(s) on the warranty claim and include an accurate problem description leading to the
controller replacement.
10. For other controllers, Replace indicated controller. (ECU-ECM/GCU/TCU). See Electrical System 2200 YRM
1142. For GM 4.3L LPG engines, see LPG Fuel System, GM 4.3L Engine With GFI 900 YRM 1242. For
GM 4.3L gasoline engines, see Gasoline Fuel System, GM 4.3L Engine WITH GFI 900 YRM 1244 for all
controllers.
11. Reinstall all removed components and ensure that all connectors are completely inserted.
12. Repeat Component Operational Check.
END POSSIBLE CAUSES
  • Posted 29 Aug 2012 09:41
  • By hysterbrazil
  • joined 10 Oct'11 - 101 messages
  • rio de janeiro, Brazil
DTC 524275-4 - Mast Tilt Position Sensor OORL
POSSIBLE CAUSE
A. SENSOR SUPPLY OPEN CIRCUIT
B. SENSOR SIGNAL OPEN CIRCUIT
C. SENSOR SIGNAL SHORTED TO SENSOR GROUND
D. SENSOR SIGNAL SHORTED TO FRAME GROUND
E. SENSOR FAILURE
F. FUNCTIONAL FAILURE IN CONTROLLER
NOTE
Please refer to the end of this procedure for supporting diagrams.
COMPONENT OPERATIONAL CHECK
1. Turn power to OFF for no less than 30 seconds, and then to ON to clear displayed DTC.
YES: Go to Step 2.
NO: Problem not verified. Resume operation.
2. Conduct a quick visual inspection of all connectors/wiring associated with the displayed fault code.
Are any faults detected/observed?
YES: Repair/replace connector or wiring associated with faults found. See Electrical System 2200 YRM 1142.
NO: Go to Cause A.
CAUSE A - SENSOR SUPPLY OPEN CIRCUIT
1. Turn truck power ON.
3. Change DMM to volts scale.
4. At sensor harness connector, measure voltage across sensor supply pin (+) and sensor ground pin ( ).
Is voltage approximately 5Vdc?
YES: Sensor supply circuit wiring is OK. Go to Cause B.
NO: Go to Step 5.
5. Move negative ( ) meter lead to a clean frame ground.
YES: Sensor return has open circuit. Locate and repair/replace open wire/connection. See Wire Harness
NO: Sensor supply has open circuit. Locate and repair/replace open wire/connection. See Wire Harness Repair
2200 YRM 1128.
9030-20-124 Confidential/Proprietary - Do Not Copy or Duplicate
  • Posted 29 Aug 2012 09:40
  • By hysterbrazil
August 31 - September 2, 2025 - Sultanate of Oman, Oman
September 9-11, 2025 - Birmingham, United Kingdom
edition #1241 - 31 July 2025
CeMAT Australia was held in Sydney last week with a larger than usual contingent of Chinese OEMs. Forkliftaction speaks with a number of them to find out why they are targeting the Australian market, and what they feel needs to be done to be successful here. It’s an interesting insight into a shift in the market which is seeing some of China's largest companies making a move... Continue reading
Gillian Reed Gillian Reed
Board director, UKMHA
Director, ICHCA Australia
Senior manager of powered access business development & technical services North America, Noblelift
VP business development for Europe, Noblelift Intelligent Equipment Co
SMV (Konecranes) 33-1200C
Toyota 3FD100
Toyota 3FD100
