Toyota 7FBEU20 has no hydraulic functions (Mini Levers)
Have a 7FBEU20, 11201 with no hydraulic functions.
Truck drives and steers ok.
Showing H9-2 key on. More hydraulic function codes come on when any of the levers are pushed. (hydraulic pump motor on)
The unload valve had been changed and has continuity.
But still the same thing.
Any suggestions?
  • Posted 12 Aug 2012 07:39
  • Modified 12 Aug 2012 07:41 by poster
  • By hellokitty
  • joined 11 Mar'09 - 86 messages
echo3618@hotmail.com
Just changed a new sensor bearing for pump motor. Guess what happen.
The main CPU board burnt a few spots (visible, big) when moved one of the hydraulic mini levers.
The board is going to burnt again if I put a new one on ?
It cost 1000s $$$.
  • Posted 16 Aug 2012 09:22
  • By hellokitty
yeah....what he said.
highest probability is a bad sensor. it's very easy to replace and not really all that expensive (for a Toyota part)
do you have a book?
  • Posted 14 Aug 2012 12:25
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
If the pump bearing is sending a bad signal than the pump motor can heat up. The motor may be going so slow that it will not function hydraulics properly but have enough to steer the truck. I just had a bad bearing and but the hydraulics still worked, motor was getting hot quickly.
  • Posted 14 Aug 2012 11:52
  • By rogeriwt
thanks rick for the suggestion, but it is the pump motor getting hot and doesn't ramp up.
do you think a bad pump motor ball sensor bearing cause the no hydraulics problem?
  • Posted 14 Aug 2012 08:36
  • By hellokitty
if you are getting codes when you move the levers the problem probably isn't in the motor. however if the motor is very hot and very slow you are probably right about the sensor. you can check it in the analyzer mode, there will be two variables. one is actual speed the other is speed requested. if they are not close swap the controllers. the one on the right side sitting on the truck is the pump. if the speed numbers are still not close replace the sensor
  • Posted 14 Aug 2012 07:59
  • By rick_c
i am thinking that the motor ball sensor bearing is bad.
any ideas?
  • Posted 14 Aug 2012 01:13
  • By hellokitty
Hello
check wiring of solenoid
Do make active test on display
But i think your Cpu is defect !!!
I did have serveral time's
Need more info let me no.
Kindly regards
John.
  • Posted 13 Aug 2012 15:37
  • By johngen
  • NB, Netherlands
lift /steer is same motor. it ramps up when steer, it doesn't ramp up when i move the levers.
and the motor is hot.
when i move the levers, display shows respective codes.
  • Posted 13 Aug 2012 03:17
  • By hellokitty
does the lift / steering motor ramp up when you move the levers? is the lift motor hot? does the lever movement show on the diagnostic display?
  • Posted 12 Aug 2012 12:30
  • By rick_c
Muncie, IN, United States
