Clark NPR 15 Intermittant no hydraulics
Serial # NPR345-0203-9700....Has an intermittant problem where none of the hydraulics will respond,no lift or lower...no reach tilt or sideshift...after talking with another tech in the company that i work for he said there is possibly a broken wire in the pantograph between the two control/solenoid blocks,he says that the solenoid card sends out a refrence voltage to them and if it isnt seen coming back then the hydraulics wont work. Guess he has found this on a few occacions.
the solenoid card is new a few months ago as are the control handle switch's for lift/lower and reach/tilt sideshift push buttons.
I want to see what the consences is on this issue before i start tearing wires out of the pantograph(which is a double reach pantograph)
  • Posted 11 Aug 2012 05:58
  • By kevin_t
Found my problem today,the harness is siamesed to one of the hydraulic hoses on the pight side of the pantogragh and is routed over two diffrent rollers on the reach arms(double reach truck)...on the back side of the pulley is a guide will a small piece slide over it to keep the hose/harness centered on the larger guide pulley,well the harness somehow got wrapped up under this smaller guide and it tore into the harness/wires,causing the issue when the reach was fully extended. Repaired it temporarily until i can get the new harness as this one is pretty tore up
  • Posted 14 Aug 2012 08:47
  • By kevin_t
the one thing you said that gets me thinking it may be the pantograph harness is you say when you are reaching out is when it fails.
I would start there first
ohming out the harness shouldnt be too hard
might take 2 people but still it should be relatively easy to check.
cut or crushed harnesses in pantographs is a fairly common thing, especially if they are not routed right or tied down correctly (out of the way).
  • Posted 14 Aug 2012 08:41
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
i have this trouble in a NEW forklift, and i find......
the wires in to the handle are crushed, only re-routed these wires and the problem was solved.
try it... may be you trouble is the same....
  • Posted 14 Aug 2012 01:41
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
Switche's are good,just replaced,yes the power steering works also,just seems at times when reaching it will loose hydraulic functions,lift/lower reach tilt and side shift,going to check for broken wires in the pantograph,also after looking at the wiring schematic i am going to check wiring from brake switch that is common to all the solenoid coils it looks.
  • Posted 12 Aug 2012 07:05
  • By kevin_t
For the lift/lower I would check the switches and contactor. The aux funtions are seperate. Does the power steering work? That uses the same motor as the aux functions. Than check the leds on the card. The manual explains what they mean.
  • Posted 12 Aug 2012 07:00
  • By rogeriwt
Thanks Carlos, but i already have the manual,and no i am not changing out the solenoid card.
  • Posted 11 Aug 2012 08:03
  • By kevin_t
Hi Kevin, check you email.
Regards
  • Posted 11 Aug 2012 07:59
  • By carlos_r
  • joined 12 Oct'10 - 37 messages
  • zapopan jalisco, Mexico
sem.montacargas@hotmail.com
Toyota 4FD240
UN Forklift FD35T-C2JB2
Deborah Baker Deborah Baker
Muncie, IN, United States
Bolzoni SpA (Group HQ)
