7FBMF18 error code F01 display failure
I've changed address motor brushes and remains the same, does not walk this blocked only works the elevation, please if someone knows something about the error code F01 and can help me
  • Posted 10 Aug 2012 04:32
  • Modified 14 Aug 2012 04:37 by poster
  • By juanpascual_t
  • joined 10 Aug'12 - 24 messages
  • Spain
Jhon_T
I need the instructions on screen if you were so kind thanks, greetings
  • Posted 15 Aug 2012 04:19
  • By juanpascual_t
  • Spain
Jhon_T
You don't need pc
Its all possible with display
Matching the truck thats all
The cpl print SAS you must replace it
Sometimes iss all defect hhmm
when you need instruction of display let me now
John.
  • Posted 14 Aug 2012 16:49
  • By johngen
  • NB, Netherlands
Help
  • Posted 14 Aug 2012 04:38
  • Modified 14 Aug 2012 04:39 by poster
  • By juanpascual_t
  • Spain
Jhon_T
There was a short in the motor's steering I ride with new brushes, also I have changed the mosfeet (transistor) that was open, but still the same.
I think that will damage any of the two plates that bears next to the transistor, but not is which and would like to know if I am asking the replacement: not is if you do programming, I was stopped not knowing if I can change it without having to program anything only have PC to linde.
for toyota don't have, you cannot call and only mounted?
help
Thank you
  • Posted 14 Aug 2012 04:06
  • By juanpascual_t
  • Spain
Jhon_T
hello you don't have steering F01 means
Ps Powersteering main circuit open
This is a AC truck but only the steering motor is A DC motor, the problem are the brusch of motor
When you change them and still got F01 You have problem wit SAS print Leftside of truck in the back There mounted transistor on it they blow away(defect) hopefull the print is okay,
Always check the brush of this type of truck
when you need more help let me no
Kindly regards
John.
  • Posted 13 Aug 2012 15:29
  • By johngen
  • NB, Netherlands
Yes, it is.
Series 7 with AC Technology engines thanks
serial: 7FBMF-18-10300 model: 7FBMF16
ONLY the Sears motor is DC technology from DIRECION
  • Posted 11 Aug 2012 04:03
  • Modified 11 Aug 2012 05:01 by poster
  • By juanpascual_t
  • Spain
Jhon_T
Are you sure about the model?The 7series are AC technologie,motors are brushless.Can you confirm that model and serial number?Thanks.
  • Posted 10 Aug 2012 21:23
  • By feitor
  • joined 6 Jan'11 - 161 messages
  • Leiria, Portugal
my email: rc.feitor@hotmail.com
JCB 533-105
Ice 24INCH-AUTO-SCRUBBER
USD6,396
JCB 533-105
USD6,396
