Linde Error code
Hi, Can someone tell me what code T356 and 999.9 means on a Linde H40D FL15. Thanks for the help.
  • Posted 4 Aug 2012 05:20
  • By dyke_y
  • joined 4 Aug'12 - 2 messages
Hi. I have à prblme withe code T603, what is the solution can same one give us a answer please, thnx.
  • Posted 10 Jul 2021 01:27
  • By Sefiane_Menzer
  • joined 10 Jul'21 - 1 message
  • Algeria
Soufiane
Thanks bro!!
  • Posted 29 May 2019 04:20
  • By juan_t
  • joined 28 May'19 - 2 messages
  • Mexico
Fault 260 Lifting
Precondition:
The controller detects that the solenoid current in the circuits Aux 1/A and Aux 1/B is too high.
Effect on the truck:
AUX1 (supplementary function 1) disabled
Possible causes:
1. Valve (2Y5) defective.
2. Valve (2Y6) defective.
3. Connector (2X5) defective.
4. Connection between the valves (2Y5,2Y6) and the controller (N1:90,N1:82,N1:112) short-circuited or faulty.
  • Posted 29 May 2019 04:17
  • By michel_v
  • noord holland, Netherlands
Hi, did someone find The L-260 error code for an H35D Linde??
  • Posted 28 May 2019 10:23
  • Modified 28 May 2019 10:25 by poster
  • By juan_t
  • Mexico
start whit good serial nummer
  • Posted 22 Apr 2019 15:29
  • By michel_v
what steps should be taken,can i clean control valve?
  • Posted 21 Apr 2019 15:25
  • Modified 21 Apr 2019 15:28 by poster
  • By zamzam_r
  • joined 20 Apr'19 - 11 messages
  • Indonesia
260 PWM signal valve coil not correct: Lifting i take dis from 387 sery
  • Posted 21 Apr 2019 14:57
  • By michel_v
Hi,can someone tell me how to sloved linde e25s error l260
  • Posted 20 Apr 2019 19:49
  • By zamzam_r
  • Indonesia
Linde
Thnks
  • Posted 20 Apr 2019 19:48
  • By zamzam_r
  • Indonesia
Thanks for help it will be working. I change the Valve&solenoids (2Y4)&(2Y3) THANKS again
  • Posted 19 Oct 2016 23:46
  • By namdev_s
  • joined 19 Oct'16 - 16 messages
  • maharashtra, India
Fault 255 Lifting
Precondition:
The controller detects that the solenoid current in the circuits Tilt Forward/Tilt Back is too low.
Tilting function disabled
Possible causes:
1. Valve (2Y3) defective.
2. Valve (2Y4) defective.
4. Connection between the valves (2Y3, 2Y4) and the controller (N1:91,N1:92,N1:107) broken or faulty.
  • Posted 19 Oct 2016 17:20
  • By michel_v
Hi can samone tell me what is code L254,L255
  • Posted 19 Oct 2016 14:25
  • By namdev_s
  • Posted 19 Oct 2016 13:49
  • By namdev_s
pomp reverse current zero whith power stage activated
best regards
  • Posted 4 Aug 2012 19:41
  • By michel_v
October 15-16, 2025 - Las Vegas, United States
November 13-14, 2025 - Berlin, Germany
edition #1242 - 7 August 2025
In this week’s Forkliftaction News , we take a closer look at the main theme coming out of the recent CeMAT Australia event in Sydney: automation; why some are holding back and why not everyone will automate... Continue reading
David Wells David Wells
Chief executive, Logistics UK
National business development manager, Roadpod
Senior vice president, PEAC Solutions
Board director, UKMHA
