How to adj the height speed limits on a R30CH.
Where would the height speed adj be located at. Had to replace a 24" switch. Now have a creep speed. Note:Other hands may have been in it before i started.
  • Posted 15 Jul 2012 22:08
  • By fisherman
  • joined 31 Mar'12 - 8 messages
fix it properly
There is a PDF manual that addresses this online.
  • Posted 6 Mar 2020 11:09
  • By chris_wilson
  • joined 6 Mar'20 - 3 messages
Chris W
are you positive you wired the switch in correctly? if this was a normally closed circuit and you wired the switch it normally open, this would be the symptom. or maybe the switch is miss adjusted and hitting when it should not or vice versa?
  • Posted 16 Jul 2012 00:18
Crown RD572513TT6860R
Linde C4230TL5
Linde C4230TL5
