linde x394
Hello
I need information on the errors L 221, L222, L237
and how to remove them
greets Chris
  • Posted 30 Jun 2012 02:10
  • By krzysztof_k
  • joined 2 Feb'11 - 129 messages
  • śląśk, Poland
Hello ,
Can you help me too with the full error list for linde h45d , 394 ?
Thank you !
Best Regards!
  • Posted 10 Jan 2014 04:43
  • By gabi_g
  • joined 1 May'13 - 90 messages
gabihdh at gmail dot com
hello
Can you send the sheets to the trolley 394 H45D
and error codes
my mail Chris at a-service dot com
greets Chris
  • Posted 3 Jul 2012 04:15
  • By krzysztof_k
  • śląśk, Poland
hello
if you can send me these error codes again because there was no domino
is damaged you can Linde H45D me joistlka litter number and the number of mast potercjometru excursion because I can not locate it in the catalog
greets Chris
  • Posted 30 Jun 2012 22:11
  • Modified 30 Jun 2012 22:12 by poster
  • By krzysztof_k
  • śląśk, Poland
The codes have been sent to your email can you tell me which model size 394x you have so i can send you the correct info
H40D
H40T
H40V
H45D
H45T
H45V
H50-500D
H50-500T
H50-500V
  • Posted 30 Jun 2012 05:50
  • Modified 30 Jun 2012 05:52 by poster
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
Hello
Can you send me the error codes and the deployment of sensors
Where could this sensor mast excursion
greets Chris
  • Posted 30 Jun 2012 05:11
  • By krzysztof_k
  • śląśk, Poland
You have problem with Hydraulics
Fault 221
1 Tilt angle sensor 2b3 defective.
2 Connection between tilt angle sensor 2b3 and controller N1:30,N1:88,N1:103,N1:118 faulty
Fault 222
The controller detects that one of the joysticks was not in neutral on start up
1 Joystick mechanically not in neutral position
2 Joystick or connection defected
Fault 237
The controller detects that the potentials N1:31,N1:104 supplied by the joystick 2b2 for auxilary hydraulics are not plausible.The sum of these potentials is too high.
1 Jotstick 2b2 defected
2 Connector 2x4 defected
3 Connection between joystick 2b2 and controller N1:31,N1:104 faulty...
Hope this helps you
i will also send you the full error list
  • Posted 30 Jun 2012 03:40
  • Modified 30 Jun 2012 03:46 by poster
  • By powerlifter
A good engineer is a helpful engineer
