You have problem with Hydraulics
Fault 221
1 Tilt angle sensor 2b3 defective.
2 Connection between tilt angle sensor 2b3 and controller N1:30,N1:88,N1:103,N1:118 faulty
Fault 222
The controller detects that one of the joysticks was not in neutral on start up
1 Joystick mechanically not in neutral position
2 Joystick or connection defected
Fault 237
The controller detects that the potentials N1:31,N1:104 supplied by the joystick 2b2 for auxilary hydraulics are not plausible.The sum of these potentials is too high.
1 Jotstick 2b2 defected
2 Connector 2x4 defected
3 Connection between joystick 2b2 and controller N1:31,N1:104 faulty...
Hope this helps you
i will also send you the full error list
