Hydraulic Issue
I lift my product up lets say a minimum of 24". I stop lifting. Then when I go back to lift higher the product will go down instead of up. Any ideas? Thanks.
  • Posted 26 Jun 2012 00:16
  • By ATK1
  • joined 27 Jan'12 - 74 messages
  • South Dakota, United States
allenk@ntlifts.com
clean the pressure relief valve in the main hyd valve. its located on the main inlet section of the valve body. change the orings too.
  • Posted 29 Jul 2012 22:15
  • By dozer
  • joined 22 Feb'09 - 15 messages
Thanks.
  • Posted 26 Jun 2012 22:29
  • By ATK1
bad check valve in lift section of control valve?
adjustment on lift switch off a bit?
i've also seen the safety valve in the base of the primary cylinder cause strange problems with mast sequencing as well.
just a couple things that come to mind :D
  • Posted 26 Jun 2012 21:13
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
UN Forklift FD40T
Terberg YT220
