code 43
have a code 43 heading to the customers soon anyone had this before point in a direction have the book doesn't give you much though as far as possible causes.
help would be greatly appreciated
  • Posted 21 Jun 2012 06:00
  • By VAN_CEN
  • joined 8 Nov'11 - 22 messages
  • British Columbia, Canada
The control card yellow wire pin was loose re crimped and proble was resolved
  • Posted 18 Jul 2012 10:53
  • By VAN_CEN
do a volt drop test across the drive fuse and the ED contactor. You have to load test the fuse. You may read 24 volts across an unloaded fuse. Once under load you will see the voltage drop. Do the same with the ED tips. Check them under load. The voltage across an unloaded fuse may be stored voltage in the caps. A lot of guys have been burnt by a blown drive fuse.
  • Posted 29 Jun 2012 00:57
  • By mfctech
  • joined 20 Jan'12 - 7 messages
SMV (Konecranes) 12-1200B
Taylor TX175
New - Sale & Hire
Taylor TX175
New - Sale & Hire
