BT RRE 140 need service manual
I need the list of errors code or service manual for BT RRE 140 SN: 6107301.I don't have any experience with this truck.
The truck don't drive/lift and to the board have error 516.
Please send on my e-mail is cristivirgil at yahoo dot com.
Regards'
  • Posted 5 Jun 2012 16:21
  • By ilinca_v
  • joined 18 Apr'12 - 23 messages
  • Prahova, Romania
Best Regards,
cristivirgil@yahoo.com
If the connection to / or the LID itself is faulty the truck wont move even in limp home mode.
You can only disable the LID with BT TruckCom diagnostic software.
There is a known issue with the broken solder joints & BT have already fixed it in production.
On an early RRE like this im 99% certain you will find a broken solder joint on the LID connector plug / PCB connection that is easily fixed with a soldering iron, sticking the plastic part of the connector to the PCB will stop it from happening again in the future.
  • Posted 6 Jun 2012 04:12
  • By Forkingabout
  • england, United Kingdom
Thanks so much for the information that we have received.
I think are more than sufficient.
All the information that I have is the information received from the client
Tomorrow gonna go to the client and try to fix the problem(It is in a remote location and have to drive 3 hours)
Regards
Cristian
  • Posted 6 Jun 2012 03:01
  • By ilinca_v
  • Prahova, Romania
Best Regards,
Hi
Unplug the LID, remove the torx 25 screw & take the LID of the truck.
Remove the 4 x torx 10 screws & lift of the LID back cover.
Remove the 3 x torx 10 screws & lift the PCB out the housing.
The big black connector on the left, you will find 1 or more of the solder joints broken on the front face of the PCB, reflow the 4 solder joints.
I stick the black connector housing to the PCB with silicone or glue to.stop it flexing.
Have a look, im pretty sure it will cure your RRE.
  • Posted 6 Jun 2012 00:46
  • By Forkingabout
The full error code is 1:516
Yes ,this truck have LID
  • Posted 5 Jun 2012 23:14
  • By ilinca_v
  • Prahova, Romania
It would also be helpful to know which software version the truck is running as certain error codes have been deleted / added / changed during the RRE's software history.
Truck OFF
Press the I button
It should then display the truck serial number, the hour meter reading & also the software package installed which is 260038 - ****
Its the **** part of the number I really need to know to help further.
Has the truck got the LID ( Load Information Display ) hanging from the roof?
  • Posted 5 Jun 2012 20:31
  • Modified 5 Jun 2012 20:38 by poster
  • By Forkingabout
Error codes on the RRE Reflex are 4 digit X : ****
Whats the full error code?
Will the truck drive / operate in limp home mode?
Truck switched OFF
Press the I button
Press the GREEN button
Truck should now start up in limp home mode, see if it allows you drive / operate it.
ONLY if its got software version 10 or newer installed you will also need the pin code / key / keyfob the truck to start it.
Do you have a BT can service key as these allow you in to the diagnostic / service hidden menus of the truck.
I look after a fleet of RRE's & they very rarely give any trouble, not had one breakdown for a few months.
Apart from service time they never seem to be in the workshop.
  • Posted 5 Jun 2012 19:16
  • Modified 5 Jun 2012 19:28 by poster
  • By Forkingabout
