Toyota 6BPU15 Order Picker Code 51
Hey guys,
Please help. I just inherited a Toyota 6BPU15 with a code 51. It takes the truck 20 +/- seconds during travel to throw code and then goes into 1/4 mph limp mode. It runs great and lift with no problem before the 20-second counter shuts it down. Any help would be appreciated.
  • Posted 9 May 2012 09:34
  • By swedepowr1
  • joined 9 May'12 - 6 messages
code cu - steer encoder disconnected.
check steer position encoder and wiring to the steer card.
  • Posted 8 Apr 2014 19:08
  • By stam
HI, I HAVE toyota 6bpu15 order picker code CU, CAN YOU HELP ME
THANKS
  • Posted 8 Apr 2014 04:31
  • By roberto_g
  • joined 8 Apr'14 - 4 messages
  • TULTITLAN, Mexico
MSE
Hey,
I appreciate the help, guys. What I meant before was I replaced the speed sensors on top of the drive motor. They both light when hovering over the metal portion of brake drum. I guessed at.10, but truck still codes out after 20 seconds when going slow to medium speed, and much shorter time (~5-8 seconds) when running fast. I got a code CL and CP when sensors were disconnected or removed but still plugged in. I'll check the connections tomorrow; hate buying a tractor manager.
  • Posted 9 May 2012 11:36
  • By swedepowr1
did you replace steer sensor or drive motor traction (speed) sensors on top of drive motor? Toyzilla is right you need to check your connections from sensors to steer controller and also (if possible) have someone operate travel circuit while watching led on sensors when motor is turning. MAKE SURE UNIT IS OFF OF FLOOR AND BLOCKED PROPERLY BEFORE TRYING TO WATCH LED'S FOR EVALUATION. Adjust air gap between sensors & brake drum should be.12-.16 if problem continues replace steer controller, yes it's pricey. one more thing check to make sure all componente are tight and secure.Traction sensors diconnected is code description.
  • Posted 9 May 2012 11:14
  • Modified 9 May 2012 11:18 by poster
  • By Huckleberry
  • joined 20 Jul'11 - 29 messages
  • Tennessee, United States
Replaced drive motor prox zensors. Are tou saying that there could be carbon tracking on the comnections on the tractor manager? Looks like I'm in the right area. What is code 51 and are there any anolog tests that could narrow problem down?
  • Posted 9 May 2012 10:39
  • By swedepowr1
look closely at the connections on the tractor interface board. pay special attention to the wiring for the little sensors on the drive unit.
  • Posted 9 May 2012 09:51
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
Toyota launches three new stackers Columbus, IN, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
