LINDE E10 334 serie 2006
i have a Linde 334 e10 with Zapi , give EV P lift fault so i see it is a fault in the proportionel liftvalve 2Y1 or 2Y8 but everything is oke. I have calibrate the multifunctional joystick but no effect. truck has no lifting. Any idea???
  • Posted 9 May 2012 03:42
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
alkaline battery into battery in the menu set ings have a tab sheet old model valve block and valve block new model put it on new model
greetings michel
  • Posted 12 May 2012 18:10
  • By michel_v
  • noord holland, Netherlands
My friend,slap me in the face!!!
Big confusion with that serial model,a thousand apologies!
Will check the right one now.
  • Posted 10 May 2012 01:44
  • By feitor
  • joined 6 Jan'11 - 161 messages
  • Leiria, Portugal
my email: rc.feitor@hotmail.com
Have you seen a 334 serial linde E10? It have one Joystick on the left side where you standing in the machine and the upper half of the joystick are the lift function you can turn it to the left and right , the under half of the joystick handle are the traction you can turn it left and right
  • Posted 9 May 2012 20:34
  • By gc_d
Regards gc_d
You just need to swap the SAAB connectors each other,located under the armrest.If joystick(1) were bad,you will only have now sideshift for one side,and will lift ok on the joystick(2).
Hope you understand what i mean.
R.Feitor
  • Posted 9 May 2012 18:39
  • By feitor
  • Leiria, Portugal
The voltage in truckdoctor are 0,96 V , i have not try the sideshift function. I mean i must switch something for that?
  • Posted 9 May 2012 07:10
  • By gc_d
Regards gc_d
Did you try to swap the joystick by the one of the sideshift,just to test?
What is the voltage you´re having in the proportional valve?
Those joysticks are very sensitive.
Happened to me some times.
Just a guess,best regards.
R.Feitor
  • Posted 9 May 2012 04:35
  • By feitor
  • Leiria, Portugal
UN Forklift FGL25T
UN Forklift FB25N1LZ1
