Overheating
Looking for some sugestions on this unit. Have replaced thermostat, water pump, radiator, all hoses. Pulled head and checked for any restrictions or blockage. none to be found. Have checked the valves, timming and inching pedal for proper adjustments. This unit will run about 30 to 45 min. and peg the temp gauge. running at a temp of 230 F. Also replaced the fan with a high flow fan and a smaller dia. pulley, all parts put on this unit are nissan parts. Unit has good circulation through radiator. Transmission fluid temp is runing at 230 F also. Any sugestions anyone Thanks.
  • Posted 20 Apr 2012 10:15
  • By GregM
  • joined 2 Apr'12 - 26 messages
Showing items 1 - 20 of 34 results.
Taking into account was Ed T & MEngr have shared I would do the following: disconnect the torque converter from the flywheel & test temperature to completely rule out trans, then remove counterweight, open hood & check temperature to rule out air flow restrictions. Seems to me that the H25 engine doesn't seem to have a overheating problem in general- just when installed in this chassis.
  • Posted 8 May 2012 02:07
  • By bbforks
I appreciate the feedback from everyone that has posted on this form. Will post more info. later.
  • Posted 7 May 2012 15:53
  • By GregM
I thank both Ed & MEngr for your replies. I appreciate your feedback.
  • Posted 7 May 2012 11:37
  • By bbforks
bbforks;
To answer the question. The Optimum series truck has a somewhat marginal cooling system. It is often in need of TLC and "maintenance" to assist in the reduction of overheating issues.
To date the most unusual cause of an overheating engine that I have run across, has been replacement of a +400.00 USD that had restricted cores. To date I have had 62 different causes for overheating in LPG power units of industrial forklifts. If you are new at working with forklifts, some important facts to keep in your thoughts are 40% of heat waste from the engine is removed through the engines walls. The cooling air flow is from the floor, up through the radiator and out the tail weight. The smaller the openning in the tail weight the less air will flow.
In this discussion it's menione to watch for a surge in water flow when the thermostat opens and also to remove the thermostat. The H25 Nissan has a bottom by-pass thermostat, whose purpose is to create a mor even temperature between the engine's bottom and top plus determine the coolant flow direction with the engine temperature. Removal of a thermostat causes hot spots around the number 3 and 4 cylinders which could lead to cylinder wall scuffing and/or scoreing.
The thought I keep having is, Greg dealing with an engine that is operationally sound and is it governed correctly? Also, if he elects to remove the transmission for repair I should think it may be wise to find out if the trans pump and 3 packs need repair of replacement.
Greg, a normal and well tuned H25 hydraulic stall reading will be from 2000 to 2450 RPM. The trans in your forklift is a four element two stage (2 stator) torque convertor. The radiator which you replaced, does it have a part number 21460-86180? If the radiator number is different, I would question. It is an in-line 4 tube with serpintine metal fins designed for excellent cooling capabilities.
  • Posted 7 May 2012 10:25
  • By MEngr
  • Missouri, United States
BBforks, just because the trans cooling lines do not share space with the engine cooling system does not really disconnect the engine temp and trans temp completely.
One of the problems with the torque convert stator being bad is that the motor is loaded beyond normal when just running, even more when driving, as if it was having to push past almost locked brakes all the time. (why the motor speed never gets beyond 1650 RPM when fully loaded, when it should be 2300 or so, yet gets the full 2700 rpm when not loaded)
  • Posted 7 May 2012 03:11
  • Modified 7 May 2012 03:13 by poster
How's the trans temp since radiator cooler by-passed? I saw earlier in post that MEngr has experience with this model overheating-what generally is the problem? Did this truck always run hot or did these symptoms come on out of the blue?
What type of enviroment does unit operate in- hot & humid? I know you said that the cooling system parts have been replaced, but were they inspected against the old parts when replaced (radiator core size, fins per inch, # of rows of cooling fins, waterpump vanes in correct direction. I've had waterpumps with the wrong direction fins (presumably for a serpentine belt set up)). Do they have other units of this model at this location?
  • Posted 7 May 2012 02:27
  • Modified 7 May 2012 02:39 by poster
  • By bbforks
Lets review:
Greg says he put a external cooler on trans and bypassed the rad trans cooler and it still does it.
The radiator is new.
There has to be something wrong with the coolant flow or air flow.
When the motor is overheated, is the coolant in rad overheated also? If not, then the water isn't flowing properly. I would start it up cold with the rad cap off and watch to see if when the thermostat opens there is a gush flow of coolant happening. If not, then take the thermostat out, temporarily, and see if overheats. If you don't see a fast flow with the thermostat out then something else is obstucting it, or the pump has some sort of problem.
If everything is piping hot, motor and rad, is the air flowing through the rad fins properly?
It seems to me with the trans unhooked, that looking and feeling, or measuring the actual temps, of how the cooling system is working should give you an idea what's wrong.
  • Posted 7 May 2012 01:19
I agree with the trans being a possibility- but Greg stated he by-passed the trans cooling lines. Any heat from the trans would not be seen by the engine at all with this senario.
  • Posted 7 May 2012 01:13
  • Modified 7 May 2012 01:14 by poster
  • By bbforks
I would agree with you Ed. However, I would like to know one additional piece of information to better judge the stall test results, and that would be the engine and electrical systems condition. The way Greg could go now once assured the torque converter's stator sprag clutches failed is to aquire a remanufactured torque converter from Nissan's after market arm, Duralift. The cost wouldn't be all that much, and on the plus side. labor and parts would be covered under warrenty for six months.
  • Posted 7 May 2012 01:09
  • By MEngr
However BBforks, it is my experience that slipping clutches (due to an misadjusted inch spool or driver riding the inch pedal) will take at least about 45 minutes (and more likely an hour or 2) of -driving-, to heat up and transfer the heat to the engine cooling system so that it shows up in the engine temp gauge, however the torque converter stator being damaged will show (when using an infrared temp gun type thermometer) serious heat (230f) in the cooling line that comes from the transmission and that heat will be back to [almost] normal as the oil flows back to the transmission, within 15 or 20 minutes of driving (not idle sitting, but moving the truck).
I suggest using the temp gun, shooting the engine a few places (the 'freeze plugs' work best imho), shooting the radiator a few places and shooting the trans at the fittings for the cooling lines.
  • Posted 6 May 2012 23:36
bbforks;
Clutch slippage heating up the transmission oil.
  • Posted 6 May 2012 13:46
  • By MEngr
MEngr- not being a smart a**- just asking- how would a misadjusted or sticking inching spool cause an engine to overheat?
  • Posted 6 May 2012 12:56
  • By bbforks
Greg i still think you have a coolant flow problem. I would make sure i had atleast 3 row radiator, correct water pump as the new platinum pump bolt pattern is the same but different shaft and impeller dimensions and thermostat. Be sure to bleed pump housing and use 50/50 mix coolant. Use an infrared laser thermometer and shoot top of rad and bottom of rad. Should be atleast 40 to 50 degree difference in bottom than top. Remember that most of the cooling is acheived on the outer perimeter of rad. Check for dust build up in these areas. The Turkish import rad i think came with two strips of metal running horizontal across core. I had one awhile back in a diesel that eventually got a 10 blade fan. A thermostat is a must as most will overheat without. Check for obstruction in counterweight and muffler is in good shape. These problem can drive you crazy at times.
  • Posted 6 May 2012 09:44
  • By RCAV8TOR
  • Alabama, United States
try getting a laser temperature gun and take various readings around the motor
i just had a thought
could this possibly be a partially clogged head or block?
If you see abnormal hotspots in the head or block that might be an indication.
You could still be getting some circulation in the radiator because of the bypass circuit but if the head is clogged partially it could cause this problem.
I'm not discounting edwardst's suggestion because it is a high probability, in fact take temp readings on the tranny too, i just had this thought while sitting here brainstorming.
***edit***
Ok i got caught up in the rheteric and forgot he already said the trans temp is running at 230deg as well...
So does the engine cause the trans to heat up? or is the tranny heating up first and causing the engine to overheat?
MEngr does have a good point about the inching spool adjustment also, although one would think that this would cause a noticeable difference in drive performance if its heating this badly?
It may ultimately require you to start pulling systems apart and examining them more closely to find this problem.
Just a thought..... thinking outloud here ;o)
  • Posted 6 May 2012 09:30
  • Modified 6 May 2012 22:47 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Greg;
Were you able to find what the engine's speed is when the mast is tilted back completely and held long enough to read it.
What we see here will verify the cause of your engine's issue. I'm inclined to think you are having a problem with the inching control either binding or misadjusted.
  • Posted 6 May 2012 09:23
  • Modified 6 May 2012 12:29 by poster
  • By MEngr
Put an external transmission cooler on and by passed the radiator. still have the same problem. Got my hands on a exhaust gas analyzer and it all checks out.
  • Posted 6 May 2012 08:18
  • By GregM
Greg, you say, in gear, wide open throttle (not turning the wheels) your max RPM is 1650.
MEngr asked (and it is my bet he was looking at the specs):
Is the engine's max full load speed at 2300-2600 RPM and the no load speed at 2800-3000 RPM?
your numbers are; "Rpm's at full throttle in netural are 3100 rpm's, [engine good] In reverse and forward with brake held at full throttle is 1650 rpm's".
[since it should be 2300 rpm, and you only see 1650, I stick with my wag that you need a torque converter].
Bite the bullet, pull the trans, change the trans soft parts (clutches, gaskets and seals) and a reconditioned torque converter.
  • Posted 24 Apr 2012 19:56
  • Modified 24 Apr 2012 19:59 by poster
Greg;
We are looking at an engine that may be down on max allowed governed speed under full load. The engine's full load hydraulic dead head (mast tilted back and held) to see engine's speed holds at full load governed speed. If it does, you have a stator problem in the Diakin 2 speed transmission. Check pressures of trans. with oil at normal temperature and engine's speed at 1000 RPM. The main pressure should be 145-185 psi, the FWR 1 will be 142-185 psi and the FWR 2 will be the same. Also, the REV should be at 142-185 psi. The converter (IN) pressure will be 43-85 psi.
  • Posted 24 Apr 2012 12:06
  • By MEngr
Hydraulics are powered through the engine. Don't know if you have enough room to push the converter back or not, but thats a thought.
  • Posted 24 Apr 2012 10:37
  • By GregM
Not familiar with your exact model, but last thought- how hard is it to disconnect torque converter from flywheel? Would it be possible to push torque converter back so it's not rotating with engine (I understand your concern about burning up trans). Are the hydraulics powered through the engine or trans?
  • Posted 24 Apr 2012 10:21
  • By bbforks
Esie Cortez Esie Cortez
